Anyone else get the PCM 420/430 codes?????????????
Old Jun 28, 2010 | 02:00 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default Anyone else get the PCM 420/430 codes?????????????
Just swapped in some new aft o2's
nvr seen this before
Old Jun 28, 2010 | 02:16 PM
knyght4's Avatar
knyght4
Those are the catalytic codes for the rear O2s. Make sure you have them plugged up correcly? Also, do you have aftermarket headers/LT? If so, you may want to consider getting these codes tuned out.
Old Jun 28, 2010 | 02:17 PM
Rex99Coupe's Avatar
Rex99Coupe
10-PCM P0420 & P0430, common with longtube headers.
Old Jun 30, 2010 | 11:06 AM
lucky131969's Avatar
lucky131969
Originally Posted by Steve Doten
Car is 2002 Bone Stock 100%
New gm cats(take off)
New gm aft o2 sensors
Fresh ngk tr55's
still have 0430 code???
Maybe intermittent coil?
Steve,
Did you start out with both a 0420 and 0430.....and now just have a 0430 after changing the O2's? Do you have a scanner to check the O2 response?
Old Jun 30, 2010 | 11:33 AM
lucky131969
Have efi live
what to look for?
20 would show sometimes, it's just 430 now
I need to shut these down, out of vins now
I would just see if it's even responding.
To Anyone else get the PCM 420/430 codes?????????????
