Radiator and A/C lines
Old Jul 3, 2010 | 08:13 AM
joeb1kinobe's Avatar
joeb1kinobe
Default Radiator and A/C lines
I've read just about every post I could find on removing the radiator.
I've found many references to removing the auto transmission cooler lines. But when I loosed the larger line on the bottom of the radiator (passenger side) I get pressure and gas/fluid that is not the color of the transmission fluid.
These lines are clearly in the radiator and not the a/c cooler. What are they and what do I do about them?
Old Jul 3, 2010 | 08:21 AM
minitech's Avatar
minitech
Most likely the AC condenser line. Check to see if your AC still works.
Old Jul 3, 2010 | 09:41 AM
joeb1kinobe
I figured out my error. The line indeed was for a/c. I've loosened the correct ones and have removed the radiator.
Onto the steering rack and harmonic balancer.
To Radiator and A/C lines
