OIL Temp Circuit Problem
I started tracing the wire from the plug, and followed it under the fuse box through the looms...and back out into another plug..a around plug, which is where I found the damage to the wire
It sucks, because it wasn't so hard to find, but I guess when you don't know where to look, things are hard to find....so thanks for giving me a good starting point. Not sure what caused this, but I fixed it up, taped it up, and tucked everything neatly away. Now, I have 3.8 volts or so at the plug (car not running). When I plugged the sensor back in, it said oil temp 33 degrees...which can't be right. So I took the keys out, unplugged it, and attached the old sensor, put they key back in, and it said low oil temp..then when I plugged the new one in..and it said low oil temp.
I reset all the codes...do I just need to drive this for a while to get it working right again? Like I said, I have the voltage at the sensor, and its a brand new sensor....
I found my broken wire next to the battery. Truly appreciate the information.
