OIL Temp Circuit Problem
Old Jul 4, 2010 | 02:29 PM
Erics_02_z06's Avatar
Erics_02_z06
Default OIL Temp Circuit Problem
So my oil temp was reading "Low oil temp". I decided to just replace the sensor since it was only 15 bucks, but that didn't fix it. I am getting a code b1543. What types of things can I check? I am going to check the harness for 5v and ground continuity. If I find a problem, what are common weak points to check?
Old Jul 4, 2010 | 02:42 PM
lucky131969's Avatar
lucky131969
Not too much to it. Obviously, if you have headers, inspection of the wiring for heat damage. Only two wires to choose from. One is 5 volts, the other ground.
Old Jul 4, 2010 | 09:35 PM
Erics_02_z06
the wires look just fine...I'm scared to get the mulitmeter out...anybody have this happen to them?
Old Jul 4, 2010 | 09:54 PM
lucky131969
You are making quite a deal out of two wires here brother. Only two checks.....voltage and ground......come on....you can do it.....
Old Jul 4, 2010 | 10:23 PM
Erics_02_z06
lol, I know, I'm on my way to grab some batteries for my multimeter. I just am afraid the wire is going to be severed in some random hard to get to location. I'll let you know what I find out with the meter
Old Jul 5, 2010 | 03:36 PM
Erics_02_z06
ok...no 5v present at plug....whats the best way to approach this thing?
Old Jul 5, 2010 | 03:59 PM
lucky131969
Provided that you are checking with the key on...inspect the connector for corrosion. Verify you have a good reference ground for when checking voltage. Tug on the wires in the connector to make sure they are not broken at the strain relief. If all looks good, start tracing that harness..and inspect for damage.
Old Jul 5, 2010 | 04:21 PM
lucky131969
Old Jul 6, 2010 | 12:22 PM
Erics_02_z06
Okay, I am trying to understand this diagram. Does this mean the oil temp sensor doesn't connect to the PCM? Does it go to the BCM? Or does it just go to the DIC? Is there a fuse anywhere that I should check? I really don't feel like disconnecting all the connectors and pulling the loom out from behind the engine......is there a better way to follow these two wires? Honestly I can't see only this wire getting damaged in the loom behind the engine....I'm guessing the problem is somewhere else, so if I can find the other end of the wire, I would have a another starting point to work from.
Old Jul 6, 2010 | 12:44 PM
lucky131969
The oil temp sensor connects directly to the IPC only. Before it goes through the firewall, it goes through an inline connector C102, you can check the resistance value of the wiring from C102 to the sensor connector.
Old Jul 6, 2010 | 12:53 PM
Erics_02_z06
perfect! this should help a lot tonight, thanks
Old Jul 6, 2010 | 10:29 PM
Erics_02_z06
Okay, I checked from the sensor, to the c102 connector that comes out of the fuse box....it didn't appear that there was continuity. There isn't a relay/fuse in the fuse box I need to worry about is there? Is it safe to say the wire is damaged...if it means anything, I didn't have continuity on the ground or the 5v
Old Jul 6, 2010 | 11:12 PM
lucky131969
sorry for asking, but how did you check the continuity of each wire? Also, did you check each wire to ground?
Old Jul 6, 2010 | 11:29 PM
Erics_02_z06
I just measured the resistance? I checked from the ground wire at the sensor plug to the engine block, but not the 5v. It's hard to believe that wires can be severed completly, you know?
Old Jul 6, 2010 | 11:43 PM
lucky131969
The ground(low reference) is provided directly from the IPC, so checking the resistance to the engine block does not check the continuity of the wire itself.
Old Jul 7, 2010 | 12:04 AM
Erics_02_z06
Is the 5v From the ipc as well. If I connect my battery , I should have 5v from the firewall side? Is my assumption correct that I should have continuity from the green wire at the sensor plug, to the green wire on the c120 plug(fusebox side)? Thanks for your help here...I think were close here
Old Jul 7, 2010 | 12:38 AM
lucky131969
Yes, which ever side(plug or receptacle) that goes into the firewall, should have 5 volts (key on) at pin "S"...and yes, you should have continuity from the harness side connector (c120) to the sensor plug.
To OIL Temp Circuit Problem
Old Jul 8, 2010 | 01:42 AM
Erics_02_z06
Thanks for the help so far. Here is where I am at. I had 3.8 volts at the plug going into the firewall, so all appears good there. I rechecked the wires to the sensor plug, and the reference wire checked good this time, but the 5v still isn't showing continuity. I guess its time to pull these wires out, can you post a diagram of the sensor wire and the correct loom? Also, are the wires usually taped together in the loom, or can I just pull the two wires I need out of the loom? Thanks in advance,
Old Jul 8, 2010 | 11:21 PM
lucky131969
I would say just follow the loom, it almost certainly goes behind the engine. If the wire is indeed severed, then you really need to find the location, because other wires may be damaged as well. Not that it's easy to get to, but we are only talking about 4 ft of wire here. Good luck.
Old Jul 9, 2010 | 03:19 AM
Erics_02_z06
Problem solved, thanks for all your help.
I started tracing the wire from the plug, and followed it under the fuse box through the looms...and back out into another plug..a around plug, which is where I found the damage to the wire It sucks, because it wasn't so hard to find, but I guess when you don't know where to look, things are hard to find....so thanks for giving me a good starting point. Not sure what caused this, but I fixed it up, taped it up, and tucked everything neatly away.
Now, I have 3.8 volts or so at the plug (car not running). When I plugged the sensor back in, it said oil temp 33 degrees...which can't be right. So I took the keys out, unplugged it, and attached the old sensor, put they key back in, and it said low oil temp..then when I plugged the new one in..and it said low oil temp.
I reset all the codes...do I just need to drive this for a while to get it working right again? Like I said, I have the voltage at the sensor, and its a brand new sensor....
