RAM Slave Cylinder VS OEM?
Old Jul 5, 2010 | 01:15 PM
95wht6spd's Avatar
95wht6spd
Default RAM Slave Cylinder VS OEM?
Anyone used the RAM? Is it an upgrade and worth the price difference over OEM?
Old Jul 5, 2010 | 07:02 PM
tommie's Avatar
tommie
i was curious about this, but just bought an oe one......
Old Jul 6, 2010 | 09:10 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
subscribing
Old Jul 6, 2010 | 08:50 PM
95wht6spd's Avatar
95wht6spd
ttt
Old Jul 7, 2010 | 02:23 AM
TheFlyingDutchman's Avatar
TheFlyingDutchman
ditto. I'm looking at them now actually. Asking the same question...
As often as these things seem to go out on the c5s, you'd think someone would have had some experiences with them.
Old Jul 8, 2010 | 09:29 PM
95wht6spd's Avatar
95wht6spd
ttt
Old Jul 11, 2010 | 11:53 AM
95wht6spd's Avatar
95wht6spd
Anyone?
Old Jul 11, 2010 | 02:23 PM
TheFlyingDutchman
no one? I can't find any reviews of the RAM
Old Jul 11, 2010 | 02:41 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I'm doing my clutch swap next month. Spec 3+, F1 flywheel, and an OEM Slave. I never knew RAM made one. Everyone I see on here uses the OEM slave. There might be a reason for that....Just a thought.
Old Jul 16, 2010 | 09:50 AM
95wht6spd's Avatar
95wht6spd
The OE Z06 and LS1 slave are the same right?
Old Jul 16, 2010 | 10:37 AM
Venomous's Avatar
Venomous
The Ram is just an adjustable O.E. as far as I saw. The internal plunger stop is shorten for a lil further pump action, no restrictors in line, and adjustable rod to set slave extension.
I've had great results with modding a factory one like Ram does! Look up " adjustable master cylinder mod"
Old Jul 16, 2010 | 03:39 PM
95wht6spd's Avatar
95wht6spd
Are you talking about the master or slave? I have a Tick adj master.
Old Jul 29, 2010 | 04:42 PM
Joey@Tick's Avatar
0Joey@Tick
Former Vendor
The problem with the factory hydraulics is in the stock master, not the slave. Our Adjustable Master Cylinder Kit allows you to shift the car as quickly as possible, and we designed it to work with the stock GM Slave.
Old Jul 29, 2010 | 05:31 PM
Warp Factor's Avatar
Warp Factor
Joey, I think the biggest problem with factory hydraulics is that they aren't resistant to heat generated when a clutch is slipping.
Having said that, I'll acknowledge that your larger bore master can release the clutch with less pedal travel, or release a clutch which requires larger travel to release. At the tradeoff of higher pedal effort (if that matters).
To RAM Slave Cylinder VS OEM?
