Need HELP Please!! crazy DIC
The trunk also popped open and the horn started beeping.
I shut down the car and the trunk popped open and the horn starting beeping. I then disconnected the battery to stop the horn from beeping and let it sit. Reconnected the battery and I tried to restart it, now the it will not start as if there was no battery.
I read Bill Curlee's post about checking grounds but I need help on how to disengage the ground connector. Are there engagement tabs on the connectors that need to be depressed.
