AC Help / 1999 FRC
Old Jul 7, 2010 | 09:10 PM
pokeyjones's Avatar
pokeyjones
Default AC Help / 1999 FRC
Hey Gang, little help?
99 FRC stock with 68,000 miles. As it got hot this summer noticed the AC blowing but not doing much at all. Work mechanic (knows his stuff) bled the system and pronounced the system was good with no leaks. Added cans of 134a and off I went. He mentioned that the system will work better when driving as the air flow helps. Since the charge it has been 100+ degrees... takes ~5-10 minutes driving before any cool air, but not cold air... enough to cool the cabin somewhat but I'm not loving it.
Thoughts?
Old Jul 7, 2010 | 10:38 PM
ALVETTE00's Avatar
ALVETTE00
without seeing it...could be improper amount of r134a, compressor or condenser malfunction.
check if the compressor short-cycles...on/off/on/off
Check the condenser and see if the fins are full of debris...use a garden hose and using LOW pressure give it a cleaning.
Old Jul 8, 2010 | 08:57 AM
kmetros's Avatar
kmetros
Sometimes it's just too hot out for the AC to keep up. Going to recirculate mode on the climate control may be your best bet if the condensor is clean.
BTW, FRC's RULE!!!!
Kurt
Old Jul 8, 2010 | 09:01 AM
imavettegirl's Avatar
imavettegirl
clean the condenser off.
i always go to a ac shop to get ac work done.
it is what they do full time.
Old Jul 8, 2010 | 09:35 AM
pokeyjones's Avatar
pokeyjones
Default hehe
BTW, FRC's RULE!!!!
Kurt
Arctic White FRCs with gloss black rims really rule!
thanks for the advice guys!
Old Jul 8, 2010 | 11:27 AM
coanan's Avatar
coanan
If that system has never been apart since new you may have a partially blocked orfice tube; it's a small inline screen/filter. Should have at least checked/replaced that before the recharge. I live in S. Florida and rarely have the fan speed above 3; it'll freeze you out, even at idle. I went though my system and replaced the pump, dryer, and orfice tube though.
Old Jul 8, 2010 | 01:48 PM
pokeyjones's Avatar
pokeyjones
Default thanks
good advice. i'm worried about taking it in to a shop and having them start with compressor etc then find the problem is a blockage. guess i need to trust them to do their job...
wish i had shop and lift.
Old Jul 8, 2010 | 01:54 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
need to know the pressures on high and low side really.. no offense to your mechanic, but the more information we have the better
also, are the vents on one side of the car blowing cooler air than the other?
Old Jul 8, 2010 | 02:27 PM
pokeyjones's Avatar
pokeyjones
Default high low
i forget the numbers... but the high and low were normal. for some reason i'm thinking 190 but could be wrong.
mechanic is not a vette mechanic but knows his stuff. i was worried an obvious leak would show but was reassured by his take on the readings.
hope this helps. thanks gang.
Old Jul 9, 2010 | 10:27 AM
pokeyjones's Avatar
pokeyjones
Default well hell
Took her to a trusted shop and explained the situation. Looks bad, I'll know more Monday and will share the results.
Thanks for the tips, appreciated. Have a great weekend!
Old Jul 14, 2010 | 02:20 PM
pokeyjones's Avatar
pokeyjones
Default Fixed!
Hopefully it stays fixed!
Charged the system with dye... leak at Shrader valve on high side. Replaced that and topped off the system. They have kept an eye on her and no leaks. Hopefully good to go.
Fix including diagnostic $260 and change. Thanks for the advice and wish me luck that she holds.
To AC Help / 1999 FRC
