Preferred header gaskets??
Old Jul 9, 2010 | 07:11 PM
87gtNOS's Avatar
87gtNOS
Default Preferred header gaskets??
Having used system sent to me....any gasket preferences?!!
Old Jul 9, 2010 | 09:32 PM
Greg_E's Avatar
Greg_E
Stock GM gaskets are fine.
Old Jul 9, 2010 | 09:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Dont get fancy there, OEM works FINE
Old Jul 9, 2010 | 09:52 PM
jellis's Avatar
jellis
i'd use the same gaskets that are on the manifolds now. i had no problem with re-using the stock gaskets.
Old Jul 11, 2010 | 12:48 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I bought Percys dead blow aluminum gaskets.
Old Jul 11, 2010 | 01:19 AM
TRDon's Avatar
TRDon
I was told by the local performance shopp that bad things happen with gaskets on the ls1 for some reason. They suggested I use copper RTV on the head and the header and no problems will arise. It has only been a couple of weeks but it is holding strong.
Old Jul 11, 2010 | 04:32 AM
stryderss's Avatar
stryderss
hmm i would stay away from that shop. stock gaskets work great or stock gaskets from the f body work good too same bolt pattern just the port holes are round.
Old Jul 11, 2010 | 06:16 AM
LoneStarFRC's Avatar
LoneStarFRC
GM got it right!
Old Jul 11, 2010 | 06:15 PM
TRDon's Avatar
TRDon
Perhaps I should have clarified saying that they were referring to the junk graphite gaskets usually supplied by the header manufacturer. I asked what they used and they said the stockers are ok but are more expensive and they usually go for the copper RTV. They said they have never had a sealing problem using it whereas they had several blowouts on graphites.
Making a suggestion like that is far from making them a shop to avoid.
Old Jul 11, 2010 | 07:29 PM
stryderss's Avatar
stryderss
i suppose but i wouldn't want to clean that mess up if i took my headers off. If something is worth doing its worth doing correctly even if it is a bit more expensive.
Old Jul 11, 2010 | 09:48 PM
TRDon's Avatar
TRDon
The next time the headers come off if for new heads and those will be clean
Old Jul 12, 2010 | 01:10 AM
hattitude's Avatar
hattitude
These were recommended when I put my headers on. They seal great.
#12617944 @ $17.40ea
To Preferred header gaskets??
