need help separating engine from tourque tube
Old Jul 10, 2010 | 08:00 PM
futuretech's Avatar
futuretech
Default need help separating engine from tourque tube
2000 A4. Removing engine from top. All unbolted but won't come out more than an inch. I removed the three bolts from the flexplate to the flywheel. Is that all there is?
What to do to unstick coupling?
Old Jul 10, 2010 | 08:30 PM
Rob's 73's Avatar
Rob's 73
Assume you took out the torque tube to bell housing bolts.
There is a harness that is attached to the torque tube and a bell housing bolt. You need to take out the bell housing bolt that is right behind the passenger side head.
Old Jul 10, 2010 | 08:47 PM
futuretech's Avatar
futuretech
All sneaky bellhousing bolts removed. Engine is 1" away from bellhousing all the way around. I have the service manual DVD and nowhere does it talk about the connection to from the flywheel to the tube. Just want to make sure I an not missing something.
Old Jul 10, 2010 | 10:12 PM
byronhunter's Avatar
byronhunter
Loosen the propeller shaft hub clamp bolt (1). Rotate the engine at the flywheel, if necessary for alignment.
Old Jul 10, 2010 | 10:27 PM
futuretech's Avatar
futuretech
Many thanks. I thought the flywheel seperated from the flex plate to come apart.
Old Jul 12, 2010 | 12:32 AM
futuretech's Avatar
futuretech
Should the spline be in exactly the same position in relation to the hub when reinstalled (exactly the two splines that were connected befor?)
Old Jul 12, 2010 | 06:32 PM
byronhunter
Just mark it, then you won't have to worry about it!
Old Jul 12, 2010 | 07:14 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You're not suppose to remove the spline from the flex plate according to the GM manual.
Don't see a reason why you would have too.
Just unbolt the locking bolt that holds the TT drive spline and it will slide right out.
Old Jul 12, 2010 | 07:58 PM
Patches's Avatar
Patches
I simply loosened the clamp and slid the tt back and out. When I put it back in, I didn't orient it in any particular way with respect to the spline. I did follow the sm's procedure to run it with the clamp loose for several minutes to let it find center before the final torqueing.
Old Jul 12, 2010 | 09:21 PM
futuretech's Avatar
futuretech
Thanks guys I did get it apart.
To need help separating engine from tourque tube
