HVAC External Reading won't move
Old Jul 10, 2010 | 09:19 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default HVAC External Reading won't move
I pulled my shroud off today to install the vararam and the external temp on the HVAC has not changed. It reads 69 degrees. Any ideas?
Old Jul 10, 2010 | 11:31 PM
flynhi's Avatar
flynhi
Several have posted that the default is 69F when the sensor is disconnected.
Old Jul 11, 2010 | 12:44 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Thanks. I checked the connection and it was good...went cruising and something clicked, because it is working now. Who'd guessed it.
Old Jul 11, 2010 | 07:01 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
that ext. temp sensor is inexpensive at the dealer Micah. not an uncommon item to fail............
Old Jul 11, 2010 | 09:21 AM
minitech's Avatar
minitech
Any auto parts store can order one for you. about $10 - $15
Old Jul 11, 2010 | 10:08 AM
trussme's Avatar
trussme
Default here's what may have happened..
That sensor is either a resistance temperature detector (RTD's) or Thermistor. The resistance of the sensor changes with the temperature.
If you have any corrosion in any of the associated connectors it will increase the resistance that the climate controls is reading.
The resistance across the two sensor wires could be almost infinity,
in that case, your display would read a low temp of 69*.
If the sensor is not making good contact(loose) or corroded, the HVAC defaults to 69*
Once you clean it or replace it...you need to drive a few miles for it to start reading the outside temp and work correctly...
GM Part # 10248414 is aprox. $10 from the dealer and just plugs in.
Old Jul 11, 2010 | 12:58 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Thanks for the info...you too Mike.
I went cruising again last night and no issues, so maybe this issue was cleared up. It was unplugged and once I figured it out and cleared all the coulda...most histoy and one HVAC 0333 code it went away. Apparently that was the issue...the connection was not there and when. I found the code it reset things.
To HVAC External Reading won't move
