HELP check engine light/lean left bank?
Old Jul 11, 2010 | 07:03 AM
2CRUZIN's Avatar
2CRUZIN
Default HELP check engine light/lean left bank?
All, appreciate any help here. Got the constant on check engine light. Showing code 171 which is "lean left bank." Any idea what to look for? I am assuming possiblly a vacumn leak? Checked briefly and didn't find any vacumn leaks. Could it be the oxygen sensor? Any help would be appreciated!
Old Jul 11, 2010 | 08:06 AM
vettenuts's Avatar
vettenuts
Is the car stock? Check your EVAP connections to start with since the EVAP connects right near the #1 cylinder intake port. You may also want to clean the MAF.
Old Jul 11, 2010 | 09:12 AM
2CRUZIN's Avatar
2CRUZIN
Car is bone stock. Thanks, will check items you mentioned.
To HELP check engine light/lean left bank?
