1999 BCM? ECM? Problems
Old Jul 11, 2010 | 09:02 AM
crabmaster's Avatar
crabmaster
Cruising
Default 1999 BCM? ECM? Problems
Just got a 1999 and having some problems. Headlights coming on/off on their own. A/C cold then warm (compressor stays running) was told it was damper control in the dash? Traction control light comes on/off at times. Could all of this be related to a computer problem?? Any help would be appreciated, Thanks.
Old Jul 11, 2010 | 09:26 AM
FirethornC5's Avatar
FirethornC5
Do you know how to read the DTC's?
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
You can then scroll through all the computers and pull the codes. There are a list of codes and their meanings all over this forum.
I would start there. A quick check to see if you have a probable BCM problem is to pull the passenger foot/toe panel inside the car. If water has entered the cabin via an overflow from the cowl in the HVAC because of clogged drain utters or a clogged A/C drain tube, then this may be one of your problems.
Bad/corroded grounds would cause these problems also. Again, on the forum 'search' is your best option. There are posts describing all of the C5 ground locations. I cleaned all of mine and was able to get rid of a 'H' TCS code.
Old Jul 11, 2010 | 10:10 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree with everything Firethorn suggests. Good advice for a starting point.
Old Jul 15, 2010 | 08:16 PM
crabmaster's Avatar
crabmaster
Cruising
About 25 codes were hanging. Took it to local shop and they suggest replacing the ECM. I saw a guy on EBAY who can program a used one with my VIN # for $100. I'm going to give it a try. Thanks for your help!
Old Jul 15, 2010 | 08:19 PM
byronhunter's Avatar
byronhunter
Be sure to let us know the outcome!
Old Jul 15, 2010 | 09:55 PM
BigGun's Avatar
BigGun
You are about to waste your $100. Clear all the codes and see what comes back after a short drive. You have some issues to work out but replaceing the ECM is not where to start.
Old Jul 21, 2010 | 11:52 AM
crabmaster's Avatar
crabmaster
Cruising
I cleared all the codes and took a short drive. Here are the codes that came back up, p1571 hc, u1096h, u1064h, u1016h, and c1277h. Problems I still have are L headling will not go down and R won't go up. Wipers intermittent, oil psi gage pegged out. HVAC not blowing cold air-AC is running, louver problem? And trac control light won't stay out.
Old Jul 25, 2010 | 07:38 PM
crabmaster's Avatar
crabmaster
Cruising
I found the AC vent problem. It was the broken airline under the battery. Thanks to all the "smart guys" on this forum. Still working on the other issues. Headlights won't open, wipers won't work and oil psi gage pegs out when started. Please help...
Old Jul 25, 2010 | 08:09 PM
FirethornC5
Oil sender is junk. Search forum for tutorial fix. Wipers not working could be clogged udders in cowl. Search for waterleaks and you will be able to locate driver and passenger udders. Wiper is possibly shorted from water not being able to drain through clogged udders. Use search for headlamp problem. Did you pull the passenger toe board and check for corrosion on bcm? Did you check for corroded grounds? Again, use search to find the ground locations.
Old Jul 25, 2010 | 08:13 PM
dgrant3830's Avatar
dgrant3830
Look for water contamination on or in the BCM. If found, you need to clean out the udders for the HVAC. You will then need to disconnect the battery, using a grounding write strap, take apart the BCM and clean it with iso alcohol. If things still don't work after that, pull the codes again and post but it could be that the BCM is done. The headlamps might only be the headlamp switch itself as they have a high failure rate. The oil pressure sender is done. You'll need to remove the intake in order to get to it but its a fast easy job. I suggest that you locate a brass oil pressure sending unit to replace it with rather than an alluminum one. I don't know about the wipers, so I can't give you advice there other than check the fuses, all fuses, first.
Old Jul 25, 2010 | 08:18 PM
FirethornC5
I purchased a Borgwarner. Its brass and made is USA!
Old Jul 26, 2010 | 08:55 PM
crabmaster's Avatar
crabmaster
Cruising
BCM area was dry and clean. I also checked the body grounds under the hood, clean firm connections. Couldn't find the other ones, I guess I need to get it on a lift? The fuse was removed from the wipers-replaced fuse-but now they will not shut off? The headlight motors can be run up/down with a jumper but won't move with the switch, the headlights are lighting up when turned on?
Old Jul 27, 2010 | 12:40 PM
dgrant3830's Avatar
dgrant3830
Please post the codes before clearing them. Then see what comes back and post those as well.
Old Jul 29, 2010 | 12:21 PM
FirethornC5
There are 4 grounds I cleaned that directly contacted the frame underneath the hood. 2 by the headlamps (don't forget all the individual connections in the harness or the single wires going to the ground point, that's where I had about 6 inches of wire corroded inside the insulation), 1 under the master cylinder and 1 next to the battery box. There a 2 more points prone to corrosion, they are located on the frame, at the rear of the rear wheels. There's a couple of more ground points, on the car also. If you do a search someone has posted a diagram of all the locations. Your wiper motor or switch may be stuck on causing the wipers not to shut off. This will have to be troubleshot to find out where the constant power source that is causing the wiper motor to stay on is. If the BCM is not causing the wiper and headlamp issue then it's probably one or both of the switches on the column. In either case, let the troubleshooting begin!
Old Aug 27, 2010 | 07:57 PM
crabmaster's Avatar
crabmaster
Cruising
Thanks for all the help, everything is fixed! Had to replace the wiper motor. The headlight door control module was bad (under the RF headlamp). And the vacuum line was broke underneath the battery tray causing the interior louvers not to operate.
To 1999 BCM? ECM? Problems
