Starting problem 02 vert
Old Jul 11, 2010 | 06:17 PM
ant21b's Avatar
ant21b
Default Starting problem 02 vert
I have been having a strange starting problem for several years. When I put the key in and turn it I get nothing. This happens once every six months to a year. After 5 to 15 minuetes I put the key in again and it starts right up with nothing wrong. The battery currently is good just replaced it and it turns over quickly. I tried cleaning the resistor on the key but that did nothing. Is this a solenoid or starter problem from heat?
Please advise.
Old Jul 11, 2010 | 06:43 PM
lucky131969's Avatar
lucky131969
Please advise.
Since this is a biannual event, it makes it hard to troubleshoot on the spot. I would inspect the connections at the starter. Might be worth pulling the ignition switch, and inspecting the contacts. If the key is an issue, you should have codes to reflect that, and a security light that does not go out.
Old Jul 11, 2010 | 08:52 PM
bighank's Avatar
bighank
Default Shoot some contact cleaner in the key slot
Could be poor contacts on key pellet. Try some contact cleaner directly in the ignition switch.
Old Jul 11, 2010 | 09:08 PM
Blew by you's Avatar
Blew by you
I just had the same problem over the last few months, came out the other morning and the car was totally dead! got a new battery now and no problems!
Old Jul 11, 2010 | 11:18 PM
lucky131969
Right, and codes/security light would support this train of thought.
To Starting problem 02 vert
