Bought my first C5 (99 6speed) a little over a month ago (moved up from a 94 A4). Has 57,XXX miles on it. Runs fine but in my opinion the idle seems a little rough. It doesn't miss, just seems a bit rough to me. Is this normal?
No, it's not. The first thing I do when I buy a used car is establish a baseline for all future maintenance....by changing the following:
Plugs/wires
fuel/air filter
belts/hoses as required
Fluids
PCV valve+plus full inspection of all vacuum lines
It's a few hundred up front, but it gives you a starting point for everything.
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Start by cleaning the air filter...if it has a Blackwing it's probably plugged with dirt/dust. You will be amazed at the difference this makes...everyone seems to overlook this simple step, but it is vital to getting air into the engine and giving back hp and idle smoothness. If that doesn't help, get back to me...there are other things you can do.
A new air filter along with an oil change was the first thing I did after I got the car in May.
Ok, next you should look into cleaning your MAF screen and the fragile little wires inside. Get a can of CRC MAF cleaner, take everything apart, and follow the directions on the can. Crud on the wires will cause incorrect readings and the computer will not perform properly...it doesn't take much to cause a problem.
A slight rough idle is normal for the early LS1 engines. I have had a 2000 from day one and it has a slight rough idle and every 1997 to 2001 I have had listened to had a slight bump in the idle. When the engine went to 350 hp, the idle was smoothed out quite a bit. Anyway, from what you describe, I say it is a normal idle.
this thread seems to consist of the blind leading the dumb
if the MAF sensor is contaminated, there will be a " lean bank one, lean bank 2 '
THanks, I'll try that.
I became a believer when this stuff solved my rough idle. Here's a video that is a bit commercial, but informative. For us corvette guys it makes some good points to think about, especially the deposit of air filter oils onto the wires. All I know is when I cleaned the maf with this stuff the car ran like a jackrabbit and idled smooth as hell...hope this helps you. If not you can look into other areas too.
