Question for you techs - MAF sensor circuit low code
Old Mar 23, 2002 | 10:38 PM
y2kylwc5's Avatar
y2kylwc5
Default Question for you techs - MAF sensor circuit low code
I got the following code on the PCM after installing the Halltech AFR1 on my 2001 Z06. The code is as follows: PCM 0102 H C. I think the code means that the low frequency need adjustment which can be accomplished with the AFR, but I don't know if its plus or minus, or am I totally off base? Some one please help. I tried to call Halltech, but they are closed.
Old Mar 24, 2002 | 12:48 PM
y2kylwc5's Avatar
y2kylwc5
Default Re: Question for you techs - MAF sensor circuit low code (y2kylwc5)
ttt
