Transmission identification
Old Jul 13, 2010 | 01:05 AM
BOOMGUY's Avatar
BOOMGUY
Default Transmission identification
How can I tell which transmission I have?
I have a 2002 6-sp roadster. I am seeing references to to T56 and MN6 and others.
I am going to have to find a used transmission to install in the car and am not sure what to start searching for. It seems that the 1-2 synchro is badly worn...found out of course after buying the car about a month ago.
Thanks.
Old Jul 13, 2010 | 01:10 AM
Trios's Avatar
Trios
If you have a standard coupe or convertible, you have a MN6.
If you have a Z06, you have a MN12.
Both are a "T56" transmission, with different ratios.
Gear Ratios
Code:
          LS1/MN6              LS6/M12
1st Gear   2.66:1               2.97:1
2nd Gear   1.78:1               2.07:1
3rd Gear   1.30:1               1.43:1
4th Gear   1.00:1               1.00:1
5th Gear   0.74:1               0.84:1
6th Gear   0.50:1               0.56:1
Reverse    2.90:1               3.28:1
Vehicle Speed @ Redline
Code:
         LS1/MN6               LS6/M12
1st Gear   51                     48
2nd Gear   76                     69
3rd Gear   104                    100
4th Gear   136                    143
5th Gear   175                    171
6th Gear   N/A                    N/A
Old Jul 13, 2010 | 09:15 AM
BOOMGUY's Avatar
BOOMGUY
Thanks very much for the info, I appreciate it.
Old Jul 13, 2010 | 09:27 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Actually if you have a non Z06 that is stock you have a MM6. MN6 is the RPO code for a manual transmission which can be either a MM6 or M12. Either will bolt into your car without modification as long as it comes from a '97-'04.
Old Jul 13, 2010 | 12:54 PM
Trios's Avatar
Trios
Ah. Got it. I will give out correct info in the future. Thanks!
To Transmission identification
