I'm in the market for another C5.
The '98 has a fuel line return where the '99 doesn't. Is there any problem with the fuel line return? Are the LS1 engines identical?
1998: EBCM, may be mounted in the rear of car. No HUD, no twilight sentinel, perimeter bolt heads, fuel pressure regulator on the rail. Slight difference with electrical compared to 99+. 98 has a more desired fuel system, but the least desired heads and PCM.
1999: First year for HUD and twilight sentinel, fuel pressure regulator and filter integrated(located rear of car), center bolt heads.
