I have option 2 already and was suggested option 1 by a local speed shop, want to do this once so what is the power differce max power and under the curve between these 2 cams...
thanks...
ls1 paired with 243 heads, long tubes and ported tb 6speed
thanks...
Minimal if any. you second cam should produce more low end torque
243 heads do not flow much above a valve lift of .590, so no need to have valve lift of .600 with 243 heads
