passenger headlight popup problem
Old Jul 15, 2010 | 01:49 AM
cardiacnurse33's Avatar
cardiacnurse33
Cruising
Default passenger headlight popup problem
I apologize if this thread is out there somewhere but I could not find it. It first started with the gear sounding like a machine gun when closing the headlight, gear changed and all was well for about a month until the epoxy broke lose and light would not pop up. I reapplied epoxy again lasted about a month. I found on this forum about using zip ties and that has worked great, but now the head light will only pop up if i manually loosen the headlight motor 2 turns and this will last about 2 times, then i have to manually loosen the headlight motor again. does anyone have any ideas of what i can do????
Old Jul 15, 2010 | 04:32 PM
GEMcLean's Avatar
GEMcLean
Post #2
http://forums.corvetteforum.com/c5-t...iy-thread.html
