Thanks for the info. Most of this is already in the thread. I have had the car to two Dealers and they both used the scan tool with no results. The car has less than 16K miles on it and according to the last tech, the rack looks fine. Maybe another Dealer is in order or a good repair shop? There are a lot of variables and inputs involved with making this steering work. I have had 4 C5's, a C6, and a couple of Cadillacs with this system and none of them had this problem! Until now!
It sounds like the dealer only looked to see if there were any codes rather than doing the complete diagnostic procedure. I'm afraid you are going to have to take it somewhere with a Tech 2 and the knowledge to run the complete procedure, dealer or not. Other than that you can just start throwing money at it. If you go that way I'd start with the steering rack, it's cheaper than the EBCM.
You can get the rack from Zip Products in Richmond, VA for about $200.00. I've had one in my car for over a year and 20,000 miles with no problems.
In the event that it is my rack, how hard is it to replace not having a lift? I do not want to throw parts at the problem but I may have to!
Plenty of people have done it without a lift. I have only used a lift and some went very easy and others were a bit difficult. If you follow the manual procedure and have a helper you should be able to do it without a problem. Patience is the key!
Zip will require a rebuildable core in deposit for the $200 remanufactered unit. Wish I would have done that instead of getting a salvage piece.
Well it is back at the Cadillac Dealer for a pressure test. They said that they would do it no charge since they did not fix it the last time. They even gave me a Cadillac SRX to drive until they can look at my car. Customer satisfaction at it's best!
Got the car back from the Dealer today. They ran the pressure tests as per the manual and everything checked out fine!! The only casualty was the Serpentine belt which frayed during the test. It is original so I guess 7 years is OK.
BOTTOM LINE is the car is still hard to steer at low speeds and there are no codes or any other obvious problems! I have had it to 2 Dealers and twice to the one and there has been no fix!
I even went to an online Mechanic with 18 years experience "cost $9" and he suggested the same things that the Dealers tried.
Well it sounds like you've run all the tests. With the Tech 2 not showing anything wrong with the EBCM and the DIC not showing any codes I seriously doubt the EBCM is the problem. That leaves the rack.
If it were my car, at this point, I'd replace the rack. Mind you I'm not saying I'm 100% sure it's the rack but it sounds like a problem with the Magnasteer mechanism to me. Other than that I'm fresh out of ideas. Maybe someone else can chime in.
As I said previously, i am adverse to throwing parts at it. In many cases, this makes things worse! it is like going to a Doctor with a headache and He wants to do brain surgery with no data to support it!
I think that I will track back the original owner to see if anything was done that may have caused the problem.
I got hold of the last owner and He contacted the guy that He bought the car from. He had only had the car a month and was not aware of the problem. The prior owner said that he was not aware of the problem! I found it funny that there was 42# of air in the front tires "make it steer easier"?
Is it possible that a wheel speed sensor could cause the problem and not set a code? I noticed on the CarFax that the rear end was alligned a few years ago! It may be possible that one was damaged during the allignment.
Any input?
Reason: update
Bringing back up. Still hard to steer. Could it be pulley related? I found a post where the guy hads installed a underdrive pulley in prior years and it resulted in harder steering. My pulley is approx 3" in diameter. What should it be on a LS6?
If it was a result of an underdrive pulley increasing the engine RPM would alleviate the problem. Does it become easy to steer if you rev the engine?
Also I would think that sort of problem would have shown up in the pressure test the dealer performed.
Yeah, I thought about that. The pressure test was OK and increasing the RPM's does not affect the steering. I had the car raised up today to put bumper protectors on it. While at it, I checked the PS connector, the wheel sensor connections, and the steering position sensor, all looked OK.This is a crazy problem that I guess that I will have to live with!
look on the steering rack and unplug the connector.....in theory the steering should default to hydralic and have more resistance. If you can not tell a difference at idle the rack is not adjusting to the current changes from the EBTCM. Compare at idle with plug on and plug off....you will know if you have a problem...should feel a difference. If there is no difference and the commands from the EBTCM have been checked change out the rack....
Did you perform the rack resistance checks (approx 2 ohms across coil) and both pins infinite (open to ground)? Might want to make sure the wiring is correct from the EBTCM and sommeone has not reversed it making the system operate in reverse.
I don't know what size it should be or if it has been changed but it measures about 3 inches in diameter. Does anyone know what the original LS6 pulley size is?
I don't know if the LS6 pulley is the same but my 98 is about 6.5" dia.
A 3" is a drastic difference in pump speed.
I jacked up the car a crawled under it to look at the Magnasteer connector. It looked fine and while there, I checked the resistance across the coil. The resistance was 2.7 Ohms. I did not check the pins to ground as it was getting dark and trying to balance the meter where I could read it and positioning two probes was too much.
I did notice that the two wires coming out of the Magnet assy were Red and Black.
Does anyone know which wires are supposed to mate? The wires from the ECBM are Grey and White as per the Service Manual but it does not mention wire color from the Magnet assy. Just a thought, they might be reversed. I am the fourth owner so someone may have previously changed them!
I just checked the schematic and that is correct (EBCM Gray to High Side Red on Coil). Do you notice any difference in the steering pressure at idle if you take the EBCM plug off? Inspect pins C & D very carefully on the EBCM plug. If they look depressed use a small ice pick or dental pick to spring them back out. I was having some problems with my EBCM and this fix took care of them. Just be careful and do not break the spring pins. Also check the plug side pins for corrosion or wear.... Ck the coil pins to ground and the wiring/plugs discussed above. Good luck...Hope you find the problem
If you do not have any faults and all the wiring looks good it could be the EBCM not providing the correct output but I would not go there just yet......
