Cheater Slicks
Old Mar 24, 2002 | 08:42 PM
C5_PIRATE's Avatar
C5_PIRATE
Default Cheater Slicks
Anyone out there know of a good online place to get some cheater slicks???Also a place to find rims? :chevy
Old Mar 25, 2002 | 09:27 PM
Brutus0725's Avatar
Brutus0725
Default Re: Cheater Slicks (C5_PIRATE)
What are cheater slicks?????
Old Mar 25, 2002 | 10:37 PM
C5_PIRATE's Avatar
C5_PIRATE
Default Re: Cheater Slicks (Brutus0725)
Cheater slicks
Racing tires that have passed D.O.T. requirements but have reduced tread depth and compounds designed for racing. Due to the reduced tread depth these tires should be used on dry pavement only and are not suitable for normal highway use.
That sounds about right........ :crazy:
Old Mar 25, 2002 | 11:36 PM
John Nowak PE's Avatar
John Nowak PE
Try Tirerack; they are a forum vendor and carry both rims and tires.
Check out the Nitto 555R tires :D
:cheers:
Old Mar 25, 2002 | 11:57 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Cheater Slicks (John Nowak PE)
I am not sure they really make cheater slicks any more. The DOT legal tires that I have used (BFG, Hoosier, Kumho and Goodyear) all have more tread than the old drag racing cheater slicks ( a series of long dashes in the surface of the tire about 3/16 deep). The Goodyears are probably the closest. The ones I had (GSCS) had just enough tread that you could barely see and feel it and after about 4 laps it was completely gone.
Bill
Old Mar 26, 2002 | 12:49 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Default Re: Cheater Slicks (Bill Dearborn)
The closest thing to cheater slicks out there right now for the C5 would be bias ply Et streets in 26x11.5x16 which have the same type of wrinkle walls as regular slicks:D. This are just like slicks but with the BS DOT approved minimal treads, etc. Problem is will need 16 inch rims and i will be mounting mine on f body rims for the drags in the near future. Other options are L98 rims or if you have the $ CCW in Florida offes beautiful rims to fit the Mickey Thompson Et streets with skinnies in front:D Next season, after i get away from this double mortgage crap i am currently dealing with i will probably go that route.
Nitrovette :smash:
Old Mar 26, 2002 | 01:23 AM
oceanaire's Avatar
oceanaire
I forgot where I bought my ET Streets, but do an online search, and I'm sure you'll find them. I bought 26x11.5x16's. If I remember correctly, they cost somewhere between $129.00 and $159.00 each. I used 16", 86 Vette rims and had to grind the hell out of the upper A arm to get them to fit. I also had to grind just a bit on the bottom arm. If you're up to that, spray some flat black paint on the arm, install the wheel and try to turn. You'll see where you'll have to grind when you take the wheel back off as it will have rubbed the paint off.
You can get some used rims in the C4 parts for sale section. They should run you anywhere between $50.00 and $100.00 each depending on the condition.
Better yet, if you have the cash, call John at CCW. He'll hook you up with rims and tires that will fit without grinding!! I believe John is one of the Forum Vendors.
Good luck to you! :cheers: The ET Streets will dramatically drop your 60 foot times. :smash: Eric
[Modified by oceanaire, 12:24 AM 3/26/2002]
Old Mar 26, 2002 | 01:31 AM
borba's Avatar
borba
Default Re: Cheater Slicks (oceanaire)
Mickey T's use to be the best in regards with cheater slicks I just don't know if they make it in the right sizes anymore.
Old Mar 26, 2002 | 01:33 AM
oceanaire's Avatar
oceanaire
Default Re: Cheater Slicks (borba)
The ET Streets are a Mickey Thompson Tire.
To Cheater Slicks
