Remove key wait 10 seconds
Old Jul 20, 2010 | 08:55 AM
petermal's Avatar
petermal
Default Remove key wait 10 seconds
'98 C5
When cold it starts great. After running for a half an hour or more when I go to restart I get the message "Remove key wait 10 seconds". It always starts then. So far I have-
Installed CLB
New proper battery. Full voltage. Torqued appropriately.
New ignitiion switch.
Checked fuses 23, 25, 29.
Cleaned ground points except 201, 202, 301 and 302. Have been uable to locate them.
My codes are:
TCS C1281
AO-LDCM
B2252
B2282
B2284
U1064
U1096
A1-RDCM
B2253
B2283
B2285
U1064
Where should I go next?
Any help would be greatly appreciated.
Old Jul 20, 2010 | 10:16 AM
petermal's Avatar
petermal
Default Remove key
It is an automatic with 23,000 miles.
Old Jul 20, 2010 | 02:58 PM
petermal's Avatar
petermal
Default Remove key
I had a new key made with no difference. This happened on occasion after the new k harness was installed last fall and continued after the CLB was installed.
Old Jul 20, 2010 | 03:31 PM
petermal's Avatar
petermal
Default Remove key
I completely disconnected the k harness. I kept the relay attached just in case.
Old Jul 20, 2010 | 07:35 PM
petermal's Avatar
petermal
Thanks for the input. I will try the two grounds that I missed.
To Remove key wait 10 seconds
