Headlight gear replacement problem
So, I'm 2 days into the Blue Ridge Pkwy trip and I turn my Headlights on in one of the tunnels and only the left comes up. I had just replaced the Right stripped OEM nylon gear with the brass one and everything went well... I thought. The right( the one I just repaired) wouldn't come up so I turned the manual override **** on the motor about 2 rounds and tried the switch and everything worked great fro about 5-6 cycles up and down. Now when the bucket fails to raise I have to turn the **** and she works great. No noise, no slack just a perfectly working bucket.
What would be causing this. By the way, the motor doesn't strain or make any noise at all when it fails... it just needs the **** turned ( loosened) and it works 5-6 times.
Thanks,
You might check these things out.
