Another headlight problem.
Old Jul 22, 2010 | 03:25 PM
AZhitman's Avatar
AZhitman
Default Another headlight problem.
Found great info on this site for repairing my stripped headlight motor gear, which worked great.
New problem: Last night when I turned off my lights, both lights go down, then one rotates back up. If I turn them on and back off, same thing. Both down, then one pops back up.
I tried rotating it down manually, but when turning them on/off with the switch, it pops right back up while the other one functions normally.
Help?
Thanks all!
Old Jul 24, 2010 | 02:48 PM
AZhitman's Avatar
AZhitman
Bump... Amyone?
Old Jul 24, 2010 | 03:18 PM
lionelhutz's Avatar
lionelhutz
You probably just need to put 1 or 2 washers on each bolt between the motor and the mounting location. There are metal tabs with nylon bumpers that stop the arm and the arm sometimes slips past these stops. I'd recommend you take the nylon piece off and make sure the arm hits solidly on the metal stop.
Peter
Old Jul 24, 2010 | 04:35 PM
00Corvette's Avatar
00Corvette
Ditto what Peter said. There is a service bulletin on this exact issue if you do a search on it.
Old Jul 24, 2010 | 06:08 PM
byronhunter's Avatar
byronhunter
Here's the TSB:
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition: Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment
that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
Old Jul 24, 2010 | 11:52 PM
AZhitman's Avatar
AZhitman
Awesome! Thanks, Byron and Peter!
Old Aug 24, 2010 | 12:00 AM
h8s rain's Avatar
h8s rain
2nd Gear
Thannks a million. I will give it a try.
Old Aug 24, 2010 | 12:15 AM
AZhitman's Avatar
AZhitman
Worked for me. I actually just flipped the rubber bumper over (one side was all chewed up) and "boosted" it out a little with some Gorilla Glue. Added 3 washers (man, that rearmost one is a b*%*^ to reach!) Working great now.
Thanks gentlemen!!!
Old Oct 25, 2010 | 09:10 PM
Dave 127's Avatar
Dave 127
I just fliped the nylon bumper over ,problem solved.
Old Oct 25, 2010 | 09:13 PM
Dave 127's Avatar
Dave 127
Does any one know a good chevy dealer ,on the Jersey Shore Thanks Dave
To Another headlight problem.
