EBCM fuse(s)
Old Jul 22, 2010 | 04:52 PM
pad's Avatar
pad
Default EBCM fuse(s)
I am going to pull the EBCM module on my '02 Z06 tonight. Which fuse(s) should be pulled in order to cut the "power" to the unit? I do not want to simply disconnect the battery.
thanks
Old Jul 23, 2010 | 04:24 PM
pad's Avatar
pad
Removed EBCM and sent it out for a rebuild. I want to still run the car, but don't like live wires exposed in engine compartment. Any advise on which fuse(s) to pull. The manual identifies 2 fuses in fuse block located next to the battery that are related to the brakes, #5 and #52. Anyone know which one feeds the EBCM?
Old Jul 23, 2010 | 05:17 PM
His93C4's Avatar
His93C4
If you look in your owners manual or even on the fuse block under the hood you will find the fuses. There are two. Look for ABS in the legend.
Old Jul 23, 2010 | 05:22 PM
00Corvette's Avatar
00Corvette
Best to just disconnect your battery
Old Jul 23, 2010 | 05:55 PM
trussme's Avatar
trussme
read my Service ABS, Service Traction Control, Service Active Handling tutorial in the Ultimate DIY Sticky LAST PAGE about removing the EBCM & you'll get your answer:
the tutorials are in PDF form so you can click and save them
1.Tutorial for A-H,T-C, & abs problems.pdf
2. Removing EBCM .pdf
Old Aug 3, 2010 | 06:19 PM
pad's Avatar
pad
Default ABS Problem solved
Just received EBCM back from ABSFIXER. Installed in 15 minutes - problem solved.
Old Aug 4, 2010 | 07:51 AM
trussme's Avatar
trussme
Default thanks for reporting back!
(hope my tutorial was helpful)
To EBCM fuse(s)
