Idle relearn procedure
Old Mar 25, 2002 | 10:49 AM
jw38's Avatar
jw38
St. Jude Donor '14,'18,'21
Default Idle relearn procedure
Can someone explain the idle relearn procedure for me? I'm installing the Donaldson Blackwing this week and have been told that I need to do the relearn procedure. Are any special tools required? :D
Old Mar 25, 2002 | 11:09 AM
Vetts Forever's Avatar
Vetts Forever
Default Re: Idle relearn procedure (jw38)
The learned idle procedure needs to be done if any of the following events occur:
The powertrain control module (PCM) is disconnected
The battery is disconnected
The PCM loses power
The PCM is reprogrammed
The Air intake is modified
The engine idle is unstable when the learned idle position is lost. There are several methods for doing the procedure. No special tools required. These archive posts run the gambit of the ways people do the relearn:
http://forums.corvetteforum.com/zerothread?id=214659
http://forums.corvetteforum.com/zerothread?id=170382
I used the fuse removal method myself. Hope this helps.
Old Mar 25, 2002 | 08:46 PM
Roncor's Avatar
Roncor
FYI...I recently installed a Donaldson on my 02 Vert.I disconnected the negative battery cable.I did not need to do the idle relearn procedure ...IMHO "if it ain't broke-don't fix it" :seeya
Old Mar 25, 2002 | 09:07 PM
vettenuts's Avatar
vettenuts
Default Re: Idle relearn procedure (Roncor)
Not sure about this either. Is it documented in the service manual? Nothing in the owner's manual even though it recommends battery disconnect for several things.
Old Mar 25, 2002 | 09:27 PM
RogueC5's Avatar
RogueC5
Installed the Blackwing two weeks ago on my '01 MN6. Read that disconnecting the battery was optional and that the idle relearn may be necessary for A4 cars so I did neither. No problems so far after about 200 miles.
To Idle relearn procedure
