HELP!!! Removing rear axle stuck!!!
Old Jul 25, 2010 | 02:09 PM
MTL_Z06's Avatar
MTL_Z06
Default HELP!!! Removing rear axle stuck!!!
Hi guys i am in process of trying to change a cv boot.
But i am unable to remove to axle from the diff!! I thought it just slid out???
Please help me get the axle out. The axle is out of the hub but its not coming out of the differential?!
Thanks guys
Old Jul 25, 2010 | 02:19 PM
ZZOOM06's Avatar
ZZOOM06
Thanks guys
Get a prybar and pry it out of the diff. It's not that hard, just keep trying, it'll come loose.
Old Jul 25, 2010 | 02:28 PM
bumble-z's Avatar
bumble-z
Why not put it back into the hub. Put the axle nut back on. Grab the rotor and jerk the rotor downward to remove spline from diff? It does just slide out of the diff.
Old Jul 25, 2010 | 02:39 PM
lionelhutz's Avatar
lionelhutz
Because you'll just pull the outer CV joint apart.
You have to pry it out of the diff by using a bar between the diff and the axle.
Peter
Old Jul 25, 2010 | 02:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP!!! Get a BIG screwdriver and wedge it betweem the diff and the CV Housing and give it a heeve hoo and it will pop loose. Trust me. I just accomplished the same issue. DO NOT try to pull it off at the rotor side.
Old Jul 25, 2010 | 03:33 PM
ZZOOM06's Avatar
ZZOOM06
You got that right Bill. I did it the wrong way once and wound up having to replace the clip inside the CV joint because it broke into 3 pieces! NOT FUN!!!!!!!!!!!!
Jimbo
Old Jul 25, 2010 | 03:50 PM
MTL_Z06's Avatar
MTL_Z06
Got a 5$
Pry bar and it came out like butter
Thx guys.
Mark
Old Jul 25, 2010 | 08:55 PM
lionelhutz's Avatar
lionelhutz
To be correct it's the inner CV joint that would pull apart. I've got one in pieces in my garage where someone tried to remove it by pulling on it.
Peter
Old Jul 26, 2010 | 08:58 AM
MTL_Z06's Avatar
MTL_Z06
You are correct!
Mine came appart. Not a big deal since thats the side i am replacing anyways...
Thanks again guys.
Mark
To HELP!!! Removing rear axle stuck!!!
