DISCRIMINATING SENSOR - Do I need to change it?
Old Jul 26, 2010 | 08:56 AM
tappaja's Avatar
tappaja
Default DISCRIMINATING SENSOR - Do I need to change it?
After crash, both airbags changed, SDM unit is new, but still Tech 2 says something about sensor not present...
Do I need to change SENSOR,F/END INFL RST DISCRM?
position 18 on picture
Thank you
Old Jul 26, 2010 | 09:11 AM
tappaja's Avatar
tappaja
It's called IMPACT SENSOR also.
I thought that 97 have no this sensor as is part of SDM, but I am wron probably.
Old Jul 26, 2010 | 09:41 AM
rebelheart's Avatar
rebelheart
I would check and make sure the impact sensor is there for one thing and plugged in next.After that,since it was wrecked, I would look for a cut/open wire in the impact area.
Old Jul 26, 2010 | 09:48 AM
tappaja's Avatar
tappaja
Well, sensor itself is undamaged as impact area was right wheel. Connector is clean and connected to sensor, but we'll check wires for continuity.
pin 9 and splice pack #208 (instrument panel harness, grounded to G104 => below battery tray)
This is my impact area.
Old Jul 28, 2010 | 02:49 AM
tappaja's Avatar
tappaja
So sensor is not problem to buy, but I need to be 100% sure that sensor MUST BE REPLACED after collision. Can anybody confirm OR disconfirm that please?
To DISCRIMINATING SENSOR - Do I need to change it?
