Program second Key Fob
Old Jul 26, 2010 | 07:29 PM
jbihl's Avatar
jbihl
Cruising
Default Program second Key Fob
I have 0 2000 The first key fob can be programed but I can't program the second one. I know both fobs are good since either one can be programed a number one. Anyone have the solution?
Old Jul 26, 2010 | 07:49 PM
1960's Avatar
1960
I have a 2000 also,with the very same problem,try as I may,it fails to work.New battery does not help.
Old Jul 26, 2010 | 08:06 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Are you following this procedure?
Programming Transmitters
1. Turn the ignition to ON.
2. Turn the radio to OFF.
3. Press the RESET button in order to clear any IPC warning messages.
4. Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
5. Press and hold the RESET button for 3 seconds.
6. Press the OPTIONS button until FOB TRAINING message is displayed.
7. Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1ST FOB will be displayed.
8. Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
Old Jul 27, 2010 | 09:22 PM
1960's Avatar
1960
Thanks Mark,looks like the same instr'n. I've already tried.I'll try again,Bob
Old Jul 28, 2010 | 09:40 AM
markKlein's Avatar
markKlein
What message do you get when the first fob is programmed? What exactly happens at each step?
To Program second Key Fob
