need help!
Old Jul 27, 2010 | 09:27 AM
midlifetoy1's Avatar
midlifetoy1
Default need help!
Last night car was running kinda weird; getting on the highway it kinda hiccuped. I saw an amber light flash but it flashed too quickly to identify. Well this morning I ran the codes and was blown away by all this....
TCS: C1226 C1248 C1254 C1255 C1261 C1262 C1268 C1271 C1272 C1273 C1274
SDM: U1040
IPC: B0516 B0521 U 1040
HVAC: B0361 Bo441
These were all History codes withe the exception of the hVAC which were H & C. I reset everything and drove the car about 6 miles to work. As I was driving I got Service tire mon sys/service vehicle soon. When I got to work I rechecked the codes and got the following...
TCS: C1226
BCM: U1096
SDM U1096
Radio: U1096
HVAC: U1096 B0361 B0441
RFA: U1096
These were also showing as history codes.
Any ideas on what this is all about? The car is a 2002 vert with 123K miles.
Could this be a battery problem or do I need to start refinancing the house?
Old Jul 27, 2010 | 09:38 AM
dougbfresh's Avatar
dougbfresh
Sounds like a funky connection somewhere, passenger side accordian in the door would be my first place to investigate. Have you been doing anything under the hood recently??
Old Jul 27, 2010 | 10:26 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
QUOTE"
"Could this be a battery problem or do I need to start refinancing the house?"
You have a power issue BUT,,,,,,It most likely isnt the battery. You can check the battery and have it tested. Then properly torque it back in (11 ft/lbs.)
My guess is the ignition switch is starting to fail. That would be the very first thing that I would investigate. Heres a post for you.
-C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Checking the door accordion tubes is something that you SHOULD do. Its a preventative step that will help you down the road. Those rubber tubes just POP OUT and back in so it easy.
BC
To need help!
