Suspension HELLLLLLP
Old Jul 27, 2010 | 10:48 AM
dfurnas's Avatar
dfurnas
Default Suspension HELLLLLLP
So, A&A vortech kit on. Front not lowered at all and Im dragging that air dam on EVERYTHING, not the SC air dam, the stock radiator reflector> forget about inclines, michigan potholes and generally garbage roads, im scraping that plastic on hard braking>? what can I do to remedy this?
Old Jul 27, 2010 | 11:37 AM
lionelhutz's Avatar
lionelhutz
You could adjust the front spring to lift the car again. Just search this forum for lowering and do the opposite of lowering on the front of the car.
Peter
Old Jul 27, 2010 | 12:24 PM
dfurnas's Avatar
dfurnas
so its possible to raise the car from its stock height?
Old Jul 27, 2010 | 12:35 PM
lucky131969's Avatar
lucky131969
Sounds like you installed it wrong. Post pics........
Old Jul 27, 2010 | 04:30 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
You don't say what year and how many miles are on the car, but you might want to check the front spring for damage. Mine was cracked when I bought it, and it also scraped quite often. A new spring brought it back up to stock height. I then lowered it all the way on the stock bolts and it still doesn't scrape a fraction of what it did originally.
Old Jul 27, 2010 | 04:59 PM
dfurnas's Avatar
dfurnas
98 coupe, 30ish thousand miles. Ill check the springs as well thank you. probably going to "alter" the air dam a little bit.
Old Jul 27, 2010 | 05:30 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I looked at your profile and the answer is simple stiffen your
suspension. Update it go with C-6 ZO-6 parts or better.
Good luck and check your 4 wheel alignment!!
Old Jul 27, 2010 | 05:40 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
"Stock" heights seem to vary a bit from car to car, however it is possible to make adjustments as necessary.
Be careful on the front, however, as the adjuster bolts are screwed into threaded inserts that are molded into the spring. It's possible for the bolt to freeze in the insert, and if you apply too much force, you can break the insert loose.
To Suspension HELLLLLLP
