CAGS eliminator
Old Mar 25, 2002 | 06:48 PM
george watson's Avatar
george watson
Default CAGS eliminator
I installed a CAGS eliminator on my 2002 coupe.
Sometimes it works; sometimes it doesn't.
What gives?
Is it the source of the part?
Old Mar 25, 2002 | 07:01 PM
Mark VerMurlen's Avatar
Mark VerMurlen
Default Re: CAGS eliminator (george watson)
Why do you think its not working? If you think its not working because the light still comes on, this is normal. The light will still come on, but the solenoid isn't operational, so you can still shift into second. If you put in the CAGS eliminator that I've seen, there is no way the solenoid could actually function because its totally disconnected.
- Mark
Old Mar 25, 2002 | 07:24 PM
george watson
Default Re: CAGS eliminator (Mark VerMurlen)
Hey, thanks for responding.
I'll see if I can clarify a little.
I separated the original plug, put the CAGS substitute piece on the transmission, put the other CAGS piece in the other connection, installing per instructions.
Yes, I know the light doesn't matter.
Sometimes, between 15 and 19 mph, though, the gear shift will go only from 1st to 4th; other times it goes straight to 2nd with no problem.
Seems very strange to me.
Old Mar 25, 2002 | 07:46 PM
Mark VerMurlen
It sounds like you got the CAGS eliminator done correctly, so the solenoid can't be the source of the problem. I wonder if you just aren't able to get the gears to mesh properly some times. Do you ever have trouble getting into any other gears?
- Mark
Old Mar 25, 2002 | 08:09 PM
george watson
No, shifting's not an issue.
I will mention something else, although I don't think it matters -- it looked to me as if GM had designed the non-transmission connector to defeat the install of the CAGS plug.
In other words, the CAGS had 3 open slots on its connecting end, with the middle one being non-contact and just a stabilizer. The similar end on the GM switch had that stabilizer insert married to its holder on one side. The only way I could get the CAGS plug to go into the GM connector was by cutting a slot in the plastic with my pocket knife so that half-married stabilizer piece could slide in there and seat the plugs together.
It's more difficult to find words to describe this than it was to do it, and I don't see how this could have anything to do with the CAGS working intermittently.
Still puzzled...
Old Mar 25, 2002 | 08:49 PM
Mark VerMurlen
Hmmm... I'm puzzeled too. There's no way that current can get from the harness to the solenoid because they're completely separated. So I don't think the problem is really with the solenoid. I'd lean towards some problem with the shift linkage, a dragging clutch, or something in the transmission. Maybe someone else out there has an idea?
- Mark
Old Mar 25, 2002 | 09:48 PM
Straightpipes 1HD's Avatar
Straightpipes 1HD
I have a 2002 A4 but my buddy bought a 2002 M6 and installed the CAGS eliminator which he bought from Ecklers....works every time at any speed without fail. I doubt that GM would have bothered to build a CAGS eliminator defeat plug..
Old Mar 25, 2002 | 10:16 PM
ThumbsUp's Avatar
ThumbsUp
Default Re: CAGS eliminator (Straightpipes 1HD)
Sounds to me like you've unplugged the wrong solenoid as evidenced by:
1. CAGS still engages, and
2. You had to modify the connector
Several electrical connectors serve the gearbox including the reverse lockout solenoid, the trans fluid temp sensor, and the backup light switch. The CAGS is locatred on the driver's side, mid way down the assembly, and enters the gearbox at an upward angle.
Double check the install before you miss a gear and end up in reverse with a box of worthless metal scraps behind you.
Old Mar 25, 2002 | 11:05 PM
BarryR's Avatar
BarryR
There are 3 or 4 electrial connectors going to the transmission (temperature skip shift, etc.). You might have pulled the wrong connector. The service manual dioes have some pics and there is info on line about locating the solinoid plug. Good luck.
Old Mar 25, 2002 | 11:13 PM
CAU-LLC's Avatar
CAU-LLC
When we get the connector there is a web that is inside that we actually drill out of the ones we make.
Some manufactures do not take this web out and sometimes you can not install it deep enough to make a good connection. You should be able to take the web out with a needle nose pliers if it is still there.
Jim Booth / Corvette Accessories Unlimited http://www.CAU-LLC.com
Old Mar 26, 2002 | 12:04 AM
QuickSilver2002's Avatar
QuickSilver2002
Default Re: CAGS eliminator (CAU-LLC)
The most important part of the CAGS eliminator is breaking the connection.
I can see where not seating it properly(deep enough) could throw codes (since the resistor would not be there), but the solenoid would not engage.
If he is truly getting lockout from the solenoid, he has disconnected the wrong plug and could cause serious damage.
Old Mar 26, 2002 | 02:49 AM
C5go's Avatar
C5go
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I had to modify the connector when I installed it on my 2k1 as well. Works perfectly!
Old Mar 26, 2002 | 08:08 PM
george watson
Default Re: CAGS eliminator (ThumbsUp)
Hi Fellas.
This reply is to all of you who responded to my query about my CAGS installation.
Thanks to your feedback, I was able to determine it was my goof -- I did install it on the wrong connector.
Have a laugh on el stupido, because it wasn't even a connection that went to the transmission. I just replaced the first thing I saw that looked like the CAGS (dumber than ....).
Just guessing, it was probably the speed sensor or the backup light connector.
Please laugh, it really is funny, and know that I'm very grateful to each of you for helping me correct the mistake.
Thanks a ton,
George
gB-)
Old Mar 26, 2002 | 08:41 PM
ThumbsUp's Avatar
ThumbsUp
The Forum works. Nobody knows it all or has seen it all. I'm happy that this situation was corrected before you fragged your gearbox or did major hurt to yourself. or failed to illuminate your backup lights :eek:
To CAGS eliminator
