PAGING wallstAL
Old Mar 26, 2002 | 03:21 AM
AVETTE's Avatar
AVETTE
Cruise-In II Veteran
Cruise-In III Veteran
Default PAGING wallstAL
Hey, I like your 17x11 AFS GP rims. I need some. Where can I get them and where can I get the best price on them. Where did you get your tires from for them? How much did they run ya? Thanks
Old Mar 26, 2002 | 11:50 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: PAGING wallstAL (AVETTE)
Tires are from the Tire Rack, 315X35X17 drag radials, $149 ea.
Wheels are Grand Sport from AFS Wheels (17X11) 50mm offset, $237.50 ea. http://www.AFSwheels.com
[Modified by wallstAL, 7:53 AM 3/26/2002]
Old Mar 26, 2002 | 11:56 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Old Mar 26, 2002 | 12:08 PM
TLewis4095's Avatar
TLewis4095
Default Re: PAGING wallstAL (wallstAL)
Are you hooking up as good as expected with these Al? What pressure are you running them at? :cheers:
Old Mar 26, 2002 | 07:04 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: PAGING wallstAL (TLewis4095)
I run 18 psi, they will hook real good, but you must really get them hot (Line Lock).
Old Mar 26, 2002 | 07:09 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Wait, I just thought of something. I only use these at the drag strip. I normally run stock run flats around town.
To PAGING wallstAL
