Lowered car with old shocks a problem??
Old Aug 4, 2010 | 11:49 PM
VETLAG72's Avatar
VETLAG72
Default Lowered car with old shocks a problem??
Hi everyone, I need some input from my fellow Corvette Forum members!
Last weekend I finally lowered my 2002 C5 Coupe Z51 on stock bolts. I maxed them out, then backed them off a bit so I wasn't maxed - my final result was exactly 3/4" drop at all 4 corners.
Now here's my issue... The ride is definitely more harsh on small town Iowa side roads, and it seems way more bouncy/floaty. It's not scary floaty, but definitely could be in the wrong circumstances!!
My car has 109,000 miles and I have no idea if it has ever had the shocks replaced. Is there any way to tell from the numbers on the shocks when they were made? They don't look bad at all, but that doesn't mean anything I guess.
Would new C6 Z06 shocks help both the harshness and floating feeling? I didn't feel it at all before lowering.
Here's the numbers from one of the front shocks:
10431990
THD
C08/063/2/2/041
Thanks for any and all help
Old Aug 4, 2010 | 11:59 PM
Bluefire's Avatar
Bluefire
Last weekend I finally lowered my 2002 C5 Coupe on stock bolts. I maxed them out, then backed them off a bit so I wasn't maxed - my final result was exactly 3/4" drop at all 4 corners.
10431990
THD
C08/063/2/2/041
New shocks will help with the harshness. To eliminate the float and roll dump the stock "twig-like" sway bars. My Coupe was very scary at speed (> 80 mph) due to float. I swapped mine out for Z06 sways with poly bushings. The handling improvment is phenomenal.
Old Aug 5, 2010 | 12:04 AM
Bill Dearborn's Avatar
Bill Dearborn
If the ride is a lot harsher you may be bottoming out the shocks. GM doesn't recommend lowering more than 15mm measured at the ride height points on the suspension. Measuring to the fender wells isn't an exact way to determine car height since those dimensions are not controlled during assembly and can vary from car to car.
Your best bet is probably to go with some Bilstein Sports which will not bottom out on a lowered car.
Bill
Old Aug 5, 2010 | 12:13 AM
KorbenDallas's Avatar
KorbenDallas
Chances are they haven't been replaced yet... definitely consider replacing them and your swaybars. I have c6z shocks and c5z sways and it was a huge improvement at around 60k mi. I checked your profile and you have a z51, so your front spring is the same as a c5z. Your rear spring isn't as stiff, but it's not that much of a difference.
Old Aug 5, 2010 | 12:14 AM
VETLAG72's Avatar
VETLAG72
I might have to try the Z06 sway bars.
I'm pretty sure I'm not bottoming out, I don't think its THAT harsh, but I could be wrong!
Thanks guys!
Old Aug 5, 2010 | 12:18 AM
VETLAG72's Avatar
VETLAG72
That's kinda what I'm thinking! I just wish there was a way to tell how old they are. This is the first and only C5 I've ever been in so I have nothing to compare to!
Old Aug 5, 2010 | 11:28 AM
dbaker's Avatar
dbaker
Haven't had that prob with my 02Z.It's lowered on stock bolts and backed off 2 turns.
Ride is the same as before.My shocks are the OEM stuff.61K Miles.
\db2
Carolina
Old Aug 5, 2010 | 11:43 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
109,000. on the shocks. There TOAST!!!.
Pull a FRONT shock out and compress it and extend it. If it shows little or no resistance, there toast. There gas charged and compressing them should require some heavy force. You SHOULD have a tough time commpressing it and you will have a tough time increasing the rebound rate if its good..
Compare what you find to a NEW shock.
Change the shocks and sways out. You will have permagrin!
Old Aug 5, 2010 | 01:35 PM
memphis_vette's Avatar
memphis_vette
my car would bottom out every where until i replaced them with bilstein sport shocks
Old Aug 5, 2010 | 08:14 PM
VETLAG72's Avatar
VETLAG72
LOL, ok ok! I'll take one of and check it out. I'm guessing they are probably factory and that's my main problem.
Thanks!
To Lowered car with old shocks a problem??
