Header Wrap???
Old Aug 5, 2010 | 10:12 AM
Gitusum's Avatar
Gitusum
Default Header Wrap???
I am going twin turbo and was told its best to wrap the headers and xpipe. So i am putting kooks 1 7/8 headers with 3" xpipe no cats on and my questions are this.
1.should i have them coated before wrapping them?
2. does it hurt the life span of the pipes ?
thanx and any info would be great
Rick
Old Aug 5, 2010 | 10:28 AM
Dave68's Avatar
Dave68
I would check with the manufacturer. When I had Doug Thorley headers in my 68, I was told to not wrap or coat them. Otherwise the warranty would be void.
Old Aug 5, 2010 | 10:33 AM
Gitusum's Avatar
Gitusum
well the headers are used kooks and i am not buying them new but i was told wrapping them helps hold heat in for the rear turbos. I know i dont want to wrap them and they rust and fall apart or if just getting them coated will do or both should be done.
Old Aug 5, 2010 | 10:47 AM
chaase's Avatar
chaase
St. Jude Donor '12
I would get them coated. Wrapping headers sucks and it will cause them to fail early.
Old Aug 5, 2010 | 10:56 AM
Gitusum's Avatar
Gitusum
happen to know the cost of coating headers and xpipe?
Old Aug 5, 2010 | 11:54 AM
hotwheels57's Avatar
hotwheels57
They have more than one plant around the country. They'll know the cost...
http://www.jet-hot.com/
Old Aug 5, 2010 | 12:20 PM
Dave68's Avatar
Dave68
Even if you buy them used, you should still check with the manufacturer as to whether doing either or both will reduce the life of the headers. They should know more about this than anyone else.
To Header Wrap???
