Have read everything - cannot reprogram HVAC - - help!
Old Aug 5, 2010 | 01:28 PM
pazecar's Avatar
pazecar
Default Have read everything - cannot reprogram HVAC - - help!
After putting a new battery in my automatic HVAC controls started acting up. I tried relearning the HVAC system by removing the negative battery connection and also tried later by removing fuse #27. My system was working OK before the relearn attempts. Now the auto mode will not engage the blower at all and the manual mode will only work on highest setting. The system does blow cold air. Any ideas would be helpful.
Old Aug 5, 2010 | 03:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do you have the duel zone unit? If so, your HVAC fan control module bit the big one. Its on the bottom of the HVAC air box in the passengers foot well. The fan motor plugs into it.
Old Aug 5, 2010 | 04:44 PM
pazecar's Avatar
pazecar
Thanks Bill. That is exactly what I was afraid of after reading through the service manual. By the way, I am also getting B0361 and B0363 codes and have already ordered a new left actuator. I will be installing it next week. Is there ANY chance that the new actuator will clear up the fan issue? Just hoping.......
Old Aug 5, 2010 | 09:15 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your controller looks like this:
If you have a manual non DUEL ZoNE HVAC,,, this is what the board will look like:
(SMOKED BOARD)
You can take it apart and the guts look like this:
This is what happens when it smokes:
It comes apart easily
BC
Old Aug 5, 2010 | 09:16 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
(SMOKED BOARD)
You can take the DUEL ZONE Controller apart and the guts look like this:
BC
Old Aug 5, 2010 | 10:00 PM
pazecar's Avatar
pazecar
Thanks Bill. Very glad that you are out there. Sorry to bother you again, but I just ordered a new replacement controller on line for $128 delivered. I'll install both the controller and actuator next week when they get here. Once I install the two parts is there a reset process or will they automatically program when the battery is reconnected?
Old Aug 5, 2010 | 11:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
GREAT QUESTION
When you reconnect the battery ( torque the battery connectors to 11 ft/lbs) on the C5,, you should ALWAYS read and clear your DTCs:
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Thats all there is to it.
However,,
Once the battery is re-connected you will NOT have the Emissions Ready status in the PCM required to pass an emissions test and must do the required number of driving cycles to complete the emissions ready requirements necessary to pas emisions test..
Once the required driving cycles are complete, your GOOD TO GO for any emissions test.
BC
To Have read everything - cannot reprogram HVAC - - help!
