Oil consumption
Old Mar 26, 2002 | 12:22 PM
The Saint's Avatar
The Saint
Default Oil consumption
I have a 2000 6-spd convertible with 12,800 miles on the clock. I have the oil changed every 3000 miles, but I've noticed that I add between 1-2 quarts between oil changes.
I don't race/beat my car, but I don't baby it either. The Vette mechanic at my local Chevy dealer told me that kind of consumption is normal for a car with a manual transmission - especially if I get on it every once in awhile.
Figured that I'd throw it out to the forum for your opinions, and to hear what all of you are experiencing. Thanks.
Old Mar 26, 2002 | 12:29 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Oil consumption (Young Mike)
Do a search on oil consumption, you are not the only one.
:rolleyes:
Old Mar 26, 2002 | 02:22 PM
radstoy's Avatar
radstoy
I do believe there is a TSB regarding that issue. Check with the dealer. The downside is that it may require replacement of the second piston ring. :yesnod:
Old Mar 26, 2002 | 02:43 PM
ZO6LS6's Avatar
ZO6LS6
Mike, you are definitely in line for a re-ring.....................if you are using 1-2 qts per 3k, that is roughly 1.5 qts per 1500 miles................
GM standard is 1qt per 2000 miles.................
Get it fixed before the warranty expires....it will only get worse........MUCH worse. :cry
Old Mar 26, 2002 | 02:59 PM
Looks like you are using a quart every 1500 or so miles. The GM guideline for excessive oil consumption is 1 quart every 2000 miles. I had this issue with mine last fall and decided to have the rings replaced. They did a good job (no damage to car and problem was fixed - at least so far).
There is a technical service bulletin that should be available at your dealer. Talk to the service manager and get the details on what you need to do.
Good luck.
Old Mar 26, 2002 | 03:38 PM
The Saint's Avatar
The Saint
Default Re: Oil consumption (JDs00PewterCoupe)
Thanks to all. I'll get it back to the dealer soon.
Old Mar 26, 2002 | 03:50 PM
Da Kind's Avatar
Da Kind
Any reported similar problems with 2002 ZO6?
Thanks.
To Oil consumption
