Oil consumption question
Old Mar 26, 2002 | 03:49 PM
mmorse's Avatar
mmorse
Default Oil consumption question
I remember reading a posting that mentioned some oil consumption problems may stem from blowby in the PCV system. Is there a TSB on this? I have to take my car to the dealer to fix a check valve the requires removing the intake manifold. I want them to check for oil blowby also. What do I need to tell them? Any info would be appreciated.
Old Mar 26, 2002 | 03:53 PM
David Lively's Avatar
David Lively
Default Re: Oil consumption question (mmorse)
Tell them that you're experiencing excessive oil consumption; they probably need to perform a leak-down test. Not sure what exactly the procedure is, but I saw smoke coming out of the exhaust when I rev'd the engine, pointed it out to my service advisor, and had new rings the following week.
