A4 C5 Almost Died In Reverse
Old Aug 6, 2010 | 07:37 AM
LuCkYSe7eN11's Avatar
LuCkYSe7eN11
Default A4 C5 Almost Died In Reverse
I have a A4 and the other day I was backing out of my house and my car sputtered and sounded like a manual when your about to kill it. It didnt die but it sounded like it did for a second. It has happend twice now. I recently did long tube headers, cats, x-pipe, spark plugs (droped 1 so only 7 new ones), transmission filter/fluid, and diff fluid change. What should I look at since I have done a ton of stuff recently. I Havnt had any check engine lights or anything after the header install and the car seems to run the exact same except for those 2 times. Thanks for the help!
Old Aug 6, 2010 | 08:45 AM
rebelheart's Avatar
rebelheart
Sounds like you need to get it to a tuner.
Old Aug 6, 2010 | 10:01 AM
LuCkYSe7eN11
Maybe, I just got back from the auto shop. I checked my tranny fluid with the engine running and in park.... no fluid came out. I asked the mechanic that did my fluid if he put the fluid in with the engine running and he said no. I ended up putting 36oz of fluid in my tranny before it started to leak out. I have been driving on that for a week and a half I hope I didnt mess anything up and hopefully that was my problem. Both the times it happend was after I had my tranny filter and fluid changed.
Old Aug 6, 2010 | 10:55 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Nothing that you did MOD wise, should have effected the idle. You dont have to tune for headers BUT,,, tuning will improve your fuel efficiency MPG and extract any remaining HP/TQ that your not getting because your PCM is not optimized for the new set up. Your most likely running a little rich.
Check ALL your vacuum lines. They have a tendancy to rot and leak. Clean your MAF and Throttle Body blade.
After that, see what happens. You should also read and see what DTCs are present. Its always a good idea to read and CLEAR all the DTCs. That way you can see if any new ones pop up.
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
You can read the DTCs while the engine is running. If you turn the engine OFF and then back ON, that can clear some DTCs that may be important with identifying a problem. One example is a Misfire DTC (p-0300) If the engine is shut down, the DTC will clear.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
BC
Old Aug 6, 2010 | 11:02 AM
LuCkYSe7eN11
Thanks for the help I will check them before I drive home from work.
To A4 C5 Almost Died In Reverse
