C5 Fog Light Missing Fuses?
Old Aug 8, 2010 | 10:12 PM
flynhi's Avatar
flynhi
Default C5 Fog Light Missing Fuses?
My 99 vert has a Tiger Shark nose. The fog lights are in place but not working. The following fuses are missing from the engine bay fuse box:
#1 - RRFogLP (10A)
#7 - RTD (10A)
#37 - RR Fog LP
#51 - RTD - (20A)
So, the questions are: Why are these fuses missing? Does it have something to do with the replacement Tiger Shark nose? Any reason why I should not install fuses?
Theories appreciated.......
Old Aug 8, 2010 | 11:13 PM
flynhi's Avatar
flynhi
ttt
Old Aug 9, 2010 | 12:05 AM
striper's Avatar
striper
More info please. Did they work before? Did you buy the car this way or did you install the TS nose? Someone else install it for you? Have you checked to make sure the lights are wired up properly? RR Fog is for export cars with rear foglights. Find the correct fuse location first. Maybe it's blown. Do some more checking first and you might be able to answer your question yourself. Good luck!
Old Aug 9, 2010 | 12:21 AM
flynhi's Avatar
flynhi
Striper - thanks for your input.
I'm the third owner and the first owner installed the TS nose. The fogs have not worked since I bought the car. I got the window sticker and original dealer info from the NCM and it is a domestic car.
Not sure what you mean by correct fuse location - I listed all the fog fuses as shown on the lid of the fuse box.
Old Aug 9, 2010 | 12:46 AM
striper's Avatar
striper
I'm not sure what #7 & #51 are, but #1 & #37 are for Euro export cars' rear foglights. My car is not here for me to check for you. Didn't you find any other fuse locations? I think it might be #39 if I remember correctly.
Old Aug 9, 2010 | 08:26 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Grounds for the fogs go through the ground pack at the right forward, top frame rail location immediately adjacent to the hood riser.
Old Aug 9, 2010 | 08:37 PM
flynhi's Avatar
flynhi
ttt
Old Aug 10, 2010 | 01:53 AM
striper's Avatar
striper
Originally Posted by flynhi
ttt
Have you checked everything out yet? If so, what did you find as far as wiring and the #39 fuse. BTW, is the correct factory switch installed for the foglights? There also should be a relay in the same fuse box to power the fogs, check for that too.
Old Aug 10, 2010 | 09:00 AM
flynhi's Avatar
flynhi
Hi Striper,
The label in the top of the fuse box lists #39 as a fog relay and it is installed. As best I can tell, wiring is correct and the OE fog light dash panel is in place. What do you recommend as next step?
Tks.
Old Aug 10, 2010 | 12:02 PM
dgrant3830's Avatar
dgrant3830
I wish I still had the manuals but no longer do. Does the fog lamp switch light, come on when you push it? I'm thinking the power for the light comes from the relay contacts therefore indicating the relay actually closed but don't jump on me if I'm wrong....I think it worked that way. If the relay turns on and yet the lamps don't light, then look at the grounds that go through the ground pack as I mentioned before. This happened on my '99 once and it was the ground pack.
Old Aug 10, 2010 | 07:15 PM
flynhi's Avatar
flynhi
The small light adjacent to the fog light button does not come on. Missing fuses numbers 7 (10A) and 51 (20A) are labelled as RTD. Are these fog light fuses?
W.
Old Aug 10, 2010 | 07:44 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Schematic for 99 fog lights and under hood fuse box attached.
File Type: pdf
File Type: pdf
Old Aug 10, 2010 | 08:07 PM
flynhi's Avatar
flynhi
Blue 92 - Thanks a million. Very helpful.
W.
Old Aug 10, 2010 | 09:01 PM
Blue 92's Avatar
Blue 92
W.
Just let the forum know what the problem was when you find it. It might help someone else down the road.
Old Aug 11, 2010 | 02:48 AM
striper's Avatar
striper
I'm just wondering one obvious thing you could have overlooked. Have you checked out the foglight bulbs to make sure they are not burned out? It may sound silly, but I've got PIAA 1100x lights on my Z and I've had bulbs burn out. It might be worth a look if everything else is looking good at this point. I would also trace and check the grounds to make sure they are not corroded. Grounds are a very important thing on these cars.
Old Aug 11, 2010 | 10:41 PM
flynhi's Avatar
flynhi
Fog fuses in both engine bay and instrument panel fuse boxes are good.
When I press the fog light button, the indicator light does not come on. So something is disconnected.
I'll check behind the dash at the switch.
I need some guidance to trace the wiring harness that feeds the fog lights. Perhaps it was not reconnected when the Tiger Shark nose was installed by the first owner. Anyone know how I can find it without starting at the fog lights and working backward?
Old Aug 11, 2010 | 11:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sent you a schematic so you can trace out the issue,
BC
To C5 Fog Light Missing Fuses?
Old Aug 12, 2010 | 04:00 AM
Gbannish's Avatar
Gbannish
Not sure if this will help, but my 99 failed inspection due to inoperative fog lights last spring (other weird electrical problems also). I traced fuses, checked 1/2 of the ground packs, etc., no luck. Turns out my battery had died and something happened to the bcm from lack of power(?). When I removed fuse #2 (? I think) and then replaced it, that allowed the bcm to be reflashed and then the foglights immediately started working.
Greg
Old Aug 12, 2010 | 10:04 AM
flynhi's Avatar
flynhi
Greg
Hmmm - interesting.
What other weird electrical problems were you having?
W.
Old Oct 20, 2012 | 11:21 PM
MickVette's Avatar
MickVette
St. Jude Donor '13
Thanks for the great posts here. Just went through a fog light issue. The problem with my car ended up being the ground pack. Took it apart and cleaned the contacts real good. Fog lights are back in action again!
