C5 sevice
Old Aug 10, 2010 | 08:35 AM
kj217's Avatar
kj217
Default C5 sevice
hi all,
where can i download C% owner's guide and service manual?
what oil/viscosity should i use? how many quartz?
thanks,
KJ
Old Aug 10, 2010 | 08:59 AM
dougbfresh's Avatar
dougbfresh
6.5 qts with a filter, 5W30 should be printed right on the oil cap (assuming you still have the factory oil cap).
Old Aug 10, 2010 | 11:40 AM
kj217's Avatar
kj217
back to oil,, how many miles should i run the car before an oil change?
how to reset the oil life counter?
Old Aug 10, 2010 | 12:40 PM
hotwheels57's Avatar
hotwheels57
You can trust the DIC oil life monitor before changing oil/filter. Most will change at about 10% remaining, but you can safely wait until 0%.
The easiest manner to change the oil life monitor is to turn key to "on" without starting the car, then pump the gas pedal three times. It should change promptly.
All of this is in the manual.
Old Aug 10, 2010 | 02:17 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Pick up the manual. It will cost you, but it's worth it weight in gold.
Old Aug 10, 2010 | 02:25 PM
dougbfresh's Avatar
dougbfresh
Depends how you drive and the quality of the oil you use. I change mine once a year.
Old Aug 10, 2010 | 03:23 PM
Bill Dearborn's Avatar
Bill Dearborn
Change according to the OLM, once per year or 15K miles, whichever comes first. The earlier C5s had a 10K mile limit. Not sure what year it changed. I usually dumped 7 qts in my cars. Despite what worry warts say the extra half quart doesn't hurt anything.
Bill
Old Aug 10, 2010 | 04:31 PM
dougbfresh's Avatar
dougbfresh
Bill
I keep the other 1/2 qt. on the shelf for topping off later.
To C5 sevice
