V1 Settings
Old Mar 27, 2002 | 09:07 AM
shftn6's Avatar
shftn6
Default V1 Settings
I think there are three settings, Big L, little l, and one other. Can somebody tell me what each of these does? Thanks for the help.
Old Mar 27, 2002 | 09:20 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: V1 Settings (shftn6)
the big L is like city driving, it will weed out some boogus signals. Little l is like highway. There is another setting, but im not sure what it is...
Old Mar 27, 2002 | 10:34 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: V1 Settings (ICULUKN-C5)
These are settings for the Logic Mode settings. This mode helps filter out interference that will lead to false alarms.
The big L means FULL LOGIC MODE which filters out as much as it can. The half L means HALF LOGIC MODE which doesnt filter quite as much as the full mode. The A means that ALL readings are monitored and there is no filtering taking place.
I usually run the HALF LOGIC MODE all the time and sometimes switch to FULL LOGIC MODE when in the city.
Old Mar 27, 2002 | 12:04 PM
pmarone's Avatar
pmarone
You can also turn off certain bands or otherwise modify how the default settings work, which will display a "P" at start up meaning "programmed" mode. This is in addition to the L, l and A modes. The P will go away after a few moments and then only the appropriate mode setting will display.
I've programmed out X band (and I'm thinking of dropping laser too due to the falses from the high intensity LED brake lights) and run the V1 in A mode.
Pete
To V1 Settings
