ANOTHER ONE BITES THE DUST (battery)
Old Mar 27, 2002 | 09:12 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default ANOTHER ONE BITES THE DUST (battery)
This is the 2rd battery that I have had to put in the car in the last 15 months. The first time the delco leaked @ 5000 miles and the dealer had to replace the ECU harness. The dealer replaced the delco with (what else) another delco. Yesterday the car began to have a hard time starting. It would eventually crank over, but I didn't want to chance it. I took it to sears and they ran a load test on it. Battery went bad after 3 loads. So, to make a long story short, I got a die hard. Hopefully its the last battery this car will see for sometime.
Have any of you had bad experiences with delco batteries?
Old Mar 27, 2002 | 09:42 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: ANOTHER ONE BITES THE DUST (ICULUKN-C5)
I switched to a Optima battery after about 2 yrs. or owning my C5. The cost was well worth the piece of mind.
Old Mar 27, 2002 | 09:51 AM
luvinc5's Avatar
luvinc5
Default Re: ANOTHER ONE BITES THE DUST (rschiltz)
ditto
Old Mar 27, 2002 | 10:12 AM
GHT's Avatar
GHT
Default Re: ANOTHER ONE BITES THE DUST (luvinc5)
ditto the ditto. Same problem with a leaking Delco. Required 2 trips to the Dealer to get all the corroded crap fixed. Hope there is not more trouble lurking down there. Pulled the brand-new Delco and put in a Red Top.
Had the same thing happen with a Delco batt in a Suburban I previously owned. The acid leaked down the cable to where it dripped on the transmission coolant line. It eventually ate through the aluminum to create a pin hole that then sprayed a fine mist of ATF into the RF wheel assembly. Biggest damn mess I've even seen in my life. Took 2 days to cleanup.
Get a Red Top!
Old Mar 27, 2002 | 02:08 PM
2manycars's Avatar
2manycars
From: I know when the doggie he piss onna ma leg...
Cruise-In IV Veteran
St. Jude Donor '14
I've heard of leaking Delcos plenty of times, but not on an '01 or '02. I thought these had glass mat batteries in them. :confused:
Anyhow, if I were replacing mine, I'd go for the Optima. A no-brainer, it seems to me. :yesnod:
Old Mar 27, 2002 | 02:12 PM
NassyVette's Avatar
NassyVette
Default Re: ANOTHER ONE BITES THE DUST (2manycars)
Also got an optima red top. Cranks much harder now.
Peace
Old Mar 27, 2002 | 02:29 PM
Jim Weston's Avatar
Jim Weston
Default Re: ANOTHER ONE BITES THE DUST (Yellow75)
Replaced the non-leaking Delco at 2,000 miles for an Optima...
Old Mar 27, 2002 | 02:58 PM
batmann's Avatar
batmann
I also just replaced my dead - leaking Delco with a MaxTec(?) from Wal-Mart after 4 years and 27000 miles. The Max has a bright yellow casing with a black top....I was thinking this would look nice in a MY C5.
$69 plus a 3 year full replacement - no pro-rating
Old Mar 27, 2002 | 04:08 PM
Dale RED 98's Avatar
Dale RED 98
RED OPTIMA!!! Just keep's on cranking!!! :yesnod: :cheers:
Old Mar 27, 2002 | 05:13 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Ditto for me too! I replaced mine with a good ole DieHard. My years of experience tells me that we can depend on this battery! :yesnod:
Tom
To ANOTHER ONE BITES THE DUST (battery)
