switching taillights...help
Old Aug 14, 2010 | 11:10 PM
Blackkaz04's Avatar
Blackkaz04
Default switching taillights...help
The 03 I recently purchased has european amber rear tailights on it. What do I need to make the swap to the red halo LED rears? From looking at the tech article for the european rears on mid american, it looks like a separate lower harness was added to make the lower amber lights work. What do I need to do?
Old Aug 15, 2010 | 12:25 AM
pql-lbc's Avatar
pql-lbc
Remove your Euro tails as well as the add-on harness (it should just be a separate wire loom with two plugs that your stock tail light harness plugged into), sell them on the CF and recoup some $$ that you will spend on your new LED Halo's. If the Halo's are plug and play, then you're golden. Good luck.
