CLB or not?
Old Aug 5, 2010 | 10:44 PM
timritchieblue's Avatar
timritchieblue
Default CLB or not?
OK, i have try ed to do research on this, but im getting mixed reviews.
i have a 2001 auto, do i need to fix my column lock? i don't want to buy something i don't need.
Old Aug 6, 2010 | 12:14 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
did you read the sticky thread at the top of the tech section?
Old Aug 6, 2010 | 07:15 AM
timritchieblue
yes, and theirs so much info on 6 speed cars its hard to tell what applys to autos
but thanks
Old Aug 6, 2010 | 07:17 AM
timritchieblue
Originally Posted by 8VETTE7
All automatics from 2001 through 2004 do NOT have the column lock problem. Only the 1997 - 2000 automatics can experience the problem. Manual trans for all years can experience the problem.
thanks, i read on another forum that some 2001's had the prob, but i didnt know if they were speakin of 6 speeds
Old Aug 6, 2010 | 11:12 AM
vett79's Avatar
vett79
I'm stumped also. I've got the dreaded "service column lock" situation right now. I've read the sticky thread and thought replacing the battery would solve the problem. No luck. It's a '98 A4 that has had the recall done and the steering wheel moves freely. I pulled the #23 fuse for 10 seconds and the #25 is good.
How do you clear this out or do I need to purchase a CLB kit?
Old Aug 6, 2010 | 11:47 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless the column lock motor functions properly, your going to have this issue. Low voltage to the BCM can and will cause this issue. One cause of low voltage is a bad or low charged battery. The OTHER is low voltage to the BCM from other sources. That source is the IGNITION SWITCH.
The BCM gets power from multiple fused sources. Look in my ignition switch repair post and there I list the IGNITION Powered 12 VDC sources that come from the ignition switch. Measure those fuses to chassis ground and they should be the same voltage as battery output voltage. If there are significant differences between the battery and ignition switch output, that is a possible issue that needs to be looked into.
-C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
I didnt think I needed the CLB and got bit when I was at Carlisle.
BC
Old Aug 6, 2010 | 12:27 PM
vett79's Avatar
vett79
8VETTE7...I am getting the fuel shut off as well. I'll look for the GM harness and follow your suggestion from there. Any difference in CLB kits? I see several forum vendors sell them. I need to get one ordered.
Thanks for clearing things up on this subject.
Mike
Old Aug 6, 2010 | 01:41 PM
printmanjackson
it's hard to believe there are still C5's running around without a CLB.
Old Aug 9, 2010 | 11:02 AM
vett79's Avatar
vett79
I ordered a CLB and it should be here this week. In preparation I took the knee bolster off to get an idea where everything was and I found the "K harness" but it wasn't hooked up to anything. The connector mounted to the dash has Orange,Purple,Green and Black on both sides.
I cleared the codes, bought a new battery and still can't clear the message(s).
Any ideas?
Old Aug 9, 2010 | 12:23 PM
65GGvert's Avatar
65GGvert
Any ideas?
See how confusing the answers get when you hijack someone esle's thread instead of starting your own?
Old Aug 9, 2010 | 12:54 PM
vett79's Avatar
vett79
I apologize........I thought the added info would help all.
I'll start a new one.....
Old Aug 15, 2010 | 12:25 AM
Chevy Guy's Avatar
Chevy Guy
That sticky is huge and is peppered with arguing and bickering, its difficult to garner any useful info from.
Old Aug 15, 2010 | 04:09 AM
timritchieblue
To CLB or not?
