Service Column lock message, but no issues.
Old Aug 15, 2010 | 12:34 AM
Chevy Guy's Avatar
Chevy Guy
Default Service Column lock message, - "FIXED"
Hi All,
Quick question. I have a 2001 6speed and today I got the "Pull key, wait 10 seconds" message, followed by the Service column lock message. The messages are consistent and show up on every start. But here is the twist, the column unlocks fine and the car does not die, it drives fine.
I am going to reset the BCM using info I found in the sticky. Anyone have any other suggestions? I searched but didn't find anything that matched my situation.
Old Aug 15, 2010 | 03:21 AM
coolbubba's Avatar
coolbubba
Same thing happened to me but it was on Friday the 13th...?
Old Aug 15, 2010 | 03:22 AM
Carcass's Avatar
Carcass
Get a Column Lock Bypass from Corvettes of Houston,install it ,and don't worry about it.
the only real question here is:"Where would be a good place to get stranded in my Vette?"
If the answer is "nowhere" get the CLB.
Old Aug 15, 2010 | 10:02 AM
Chevy Guy's Avatar
Chevy Guy
Originally Posted by 8VETTE7
Are you saying the column physically locks with NO KEY in the ignition? Then with a key in the ignition you have the column unlock, then get the two error messages in the DIC and then the car is driveable??
Yes sir, thats what is happening. Odd right?
Old Aug 15, 2010 | 11:23 AM
Chevy Guy's Avatar
Chevy Guy
I am going to try and replace the battery first, but I do have the K harness. Its he older white one.
Tyco - 15477384
I am going to pull the BCM fuse, let it sit for a while and try the battery later tonight.
Old Aug 15, 2010 | 01:40 PM
Chevy Guy's Avatar
Chevy Guy
After some investigation, resetting the BCM, clearing codes, disconnecting the battery for a while and then and replacing the batter,. The GM K harness was the culprit. I removed the K Harness (the white Tyco part # 15477384) and plugging the column lock back together, the message is gone.
I am ordering a CLB just to be safe.
Who has the most reliable CLB?
To Service Column lock message, but no issues.
