'nother Rotor/ Caliper/Bracket question
Not looking for Opinion, but knowledge as to how to calculate the increased braking force, due to more leverage, since the swept area remains the same
Baer Front Rotor Upgrade Kit - 97-08 Corvette
http://www.pfyc.com/pc/VT4024/C6NEW/...+Corvette.html
Your Price: $599.99
The Baer Front Rotor Conversion Kit makes upgrading your front rotors to a larger size a breeze! The kit comes with a bracket to raise the caliper and converts 12.75" to 13.35" rotors. Kit works on standard wheel size for the C6, however larger front wheels are required for C5 conversion. This kit comes with two two-piece lightweight rotors and brackets. This upgrade gives you a C6 Z51 sized front rotor for your C5 or C6!
Application: 1997-2008 Corvette C5 and C6 (does not fit C6 Z06)
Your Price: $599.99
but no Math on the Leverage increase , it's part of the Equation ..
due to divorce, i lost all my good books ..
" Suspension Engineering " .. " Braking Systems Math " ..
and many more ..
do You remember Herb Adams ..??
Now the other question is will it be enough to overcome the additional inertia of the heavier wheel and tire assembly?
Thank You, for taking an interest in a Real .." technical question "
we have a increased radius ..
a fixed area ...
same clamping force ...
what's the Formula ..??
I gave the the answer you needed. take it or leave it.. and why would you care anyway , your the guy bragging about having Fake brake ducts.
I simply want to fill the open area on my 18" front wheel , with a larger disc
so ...
the question remains
is there a braking advantage to the larger disc, given the stock caliper area
However, I think its negligible and you won't notice the difference. The magnitude of torque, which is also called moment or moment of force, depends on three quantities: First, the force applied; second, the length of the lever arm connecting the axis to the point of force application; and third, the angle between the two.
τ = r x F
τ = rF sinθ
where
τ is the torque vector and τ is the magnitude of the torque,
r is the displacement vector (a vector from the point from which torque is measured to the point where force is applied), and r is the length (or magnitude) of the lever arm vector,
F is the force vector, and F is the magnitude of the force,
× denotes the cross product,
θ is the angle between the force vector and the lever arm vector.
The length of the lever arm is particularly important; choosing this length appropriately lies behind the operation of levers, pulleys, gears, and most other simple machines involving a mechanical advantage.
http://en.wikipedia.org/wiki/Work_(physics)
τ = r x F
τ = rF sinθ
where
lets solve the equation,using the Fact's we have ...
The difference in outer radius = (13.35" - 12.75") / 2 = .30"
Assuming the effective radius moves away radially an equal distance (not exactly true, but pretty close), a .30" improvement will increase the torque arm over the smaller rotor by about 4.7%. A full calculation would show this in error by up to .2% in either direction, based on my experience.
Swept area does not come into play in moment arm calculations, but pad shape does due to finite force distribution. As you mentioned, in this particular case it does not matter as the pad shape is not changing.
If the rears don't increase an equal amount, it is quite possible stopping distances may increase, not decrease. Moving the brake balance forward does not increase the effectiveness of all four tires UNLESS the rears were locking before the fronts without the rotor change.
The only potential gain here is thermal capacity, depending on the mass and mass distribution analysis of both the original rotor and the proposed replacement. Sorry, I'm not doing that here!
Chris
I'd think any extra long term or thermal capacity would come from better cooling, but there is not enough info on those rotors to tell what the cooling difference would be. But then, if these rotors have more mass they would allow more braking before the brakes over heated. Once again, no data to know that either.
Why not just find some used C6Z51 front brakes or used brake brackets and new stock type rotors? If you want the bling, then who really cares since they won't be worse than stock.
Peter
