Hey guys well I don't know when it started to happen but There is AC always coming from the Top Vent by the Dash. I try to go to any setting on the dial and still comes out. It seems that it got stuck there and now it does not move. What do I check first?
I did install a LS2 intake manifold. there is a small Vac that goes connected tot he stock ls1 intake manifold that I did not connect. Is that my issue ?
i dn't know lol that is why I ask. Does tha vac have anything to do with the AC system ?
Indeed it does. That particular vacuum line provides vacuum for the A/C controls, and A.I.R. Never leave anything disconnected, unless you understand what it is, and what it controls.
that is definitely your issue
edit: to add, dont EVER just leave a vacuum line unplugged either..at least plug it off. you probably give back 5-10 hp by having just that little vacuum leak..
no I know better than that lol.. I had capped it. Thanks guys I will plug it back tomorrow and hope it fixes all of my current issues
