Weird Cooling issues
Old Aug 17, 2010 | 09:32 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Default Weird Cooling issues
I just cleaned out my radiator and condensor and I have a 160* T-stat but I'm having some weird cooling issues. With the A/C off, in stop & go traffic, I'm experiencing 196*-199* temps. With the A/C off on the highway, I'm seeing 188*-192* temps. On the highway with the AC on, im seeing temps between 201* 205*. The cooling issue surfaces with the A/C on in stop & go traffic, where I see temps of 232*-236*. I can be sitting in traffic with the AC off and temps at 198*, but as soon as I turn the AC on, the temp rise up moderately to over 230*. Then when I turn the AC off, the temps very slowly/gradually drops to 207-212*. Why is my car overheating with the AC on in stop & go traffic??
Old Aug 17, 2010 | 09:51 AM
dougbfresh's Avatar
dougbfresh
It's not overheating.
Old Aug 17, 2010 | 10:07 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Originally Posted by All_Motor_C5LS6
I just cleaned out my radiator and condensor and I have a 160* T-stat but I'm having some weird cooling issues. With the A/C off, in stop & go traffic, I'm experiencing 196*-199* temps. With the A/C off on the highway, I'm seeing 188*-192* temps. On the highway with the AC on, I'm seeing temps between 201* 205*. The cooling issue surfaces with the A/C on in stop & go traffic, where I see temps of 232*-236*. I can be sitting in traffic with the AC off and temps at 198*, but as soon as I turn the AC on, the temp rise up moderately to over 230*. Then when I turn the AC off, the temps very slowly/gradually drops to 207-212*. Why is my car overheating with the AC on in stop & go traffic??
You need to get your story straight first. see above.
which is it? 196*-198* temps or 207-212*. Some times you find yourself in stop and go traffic and you are stopped on a concrete roadway, sometimes you are on blacktop.... in TX. the temp can be dramatic.. sometimes Black top can yield 140F. with your car sitting on top of that, there is little to no heat transfer. and you will see your temps creep up. Same difference occur in tire noise.. concrete yields a much higher decibel reading than the quieter Black top. Right now Texas is very HOT.. you are going to get hot temps.. the C5 cooling system is not as well designed for these extreme temps... You also said you have a 160 stat which has nothing to do with how hot your car will get but only how cold it will get... you never once mentioned what you changed the fan on and off temps too. how much lower than the stock settings have you set the high and low speed fans? We need good data to help diagnose the problem. If in fact, there is a problem. Happy to try to help
Bill aka ET
Old Aug 17, 2010 | 10:56 AM
All_Motor_C5LS6
Bill aka ET
My story is already straight. Once I turn the AC off if I'm stopped and at idle, it goes from 236 to 212 and sometimes from 230 to 207. Now, once I start moving it drops to 196* until I stop again where is goes up to 198* where it stays in the 196*-198* range, until I turn the AC back on.. This was this morning in 78-83* morning weather. I'm sure this afternoon when it's 100*, it's going to be much worse. My low speed fans come on at 160* and I don't know what temps the high speed fans come on.
Old Aug 17, 2010 | 10:58 AM
dougbfresh's Avatar
dougbfresh
Again, your not overheating. If your that freaked about these numbers-have your fans reprogrammed to come on sooner.
Old Aug 17, 2010 | 11:48 AM
All_Motor_C5LS6
I thought 236* was considered overheating. What temp is considered overheating?
Old Aug 17, 2010 | 01:33 PM
dougbfresh's Avatar
dougbfresh
Overheating is when you pop the pressure cap on the system and STEAM is shooting out from under the hood. Your temps are still within the NORMAL operating temps for this engine (albeit a little on the high side at times).
Old Aug 17, 2010 | 02:49 PM
Evil-Twin's Avatar
Evil-Twin
there is one of your problems right there who ever set your temp knows nothing about a C5 and cooling system...and BTW your car never over heated at any time and if you notice, never hit the red line. the fans are designed to cycle on and off...if your car is set at 160, the fans will never turn off and are probably running at half speed due to thermal break down, which is the step right before they die. The fans were designed to cycle on and off for 180,000 cycles to qualify for the European CE certification. and never to run all the time.,.,BTW your story isn't straight and I withdrawal my offer to help because your attitude or your typing skills are less than what is needed for accurate data and solution.. I wont be posting in you thread again.
Old Aug 17, 2010 | 03:24 PM
redrckt97's Avatar
redrckt97
AllMotor - I'd first check to see that the high speed fan is actually on in those conditions - they can fail. I agree with others that the on-off speeds need to be set right for the system to work properly - I do think those temps are higher than I'd like 'em and I live in the same area. There is a good shop nearby that can check it out - pm me for the name.
Old Aug 17, 2010 | 04:16 PM
KCvetteowner's Avatar
KCvetteowner
Your temps fluctuating 30 degrees between driving on the highway and sitting in stop and go traffic is probably due to one of your two fans has failed.
I had that issue for a couple months, temps would climb to about 240 degrees and then as soon as i got going again, they would drop down to around 205-210. If both fans fail you will see temps higher than 240.
Check your fans (be very careful), if one is not working, inspect the fuses in the engine bay fuse panel.
Old Aug 17, 2010 | 05:32 PM
All_Motor_C5LS6
I'm going to check my fuses first and then take steps from there. Thanks for your help guys!
Evil-Twin, I know we got off on the wrong foot, but I'd like to apologize for not being as detailed as you wanted. Thanks for your help too!
Old Aug 18, 2010 | 09:18 AM
All_Motor_C5LS6
Well, the fan issue is ruled out. I checked the fans yesterday evening and both the high and low speed fans came on. I thinking maybe faulty thermostat or faulty ECT sensor.
Old Aug 18, 2010 | 09:31 AM
dougbfresh's Avatar
dougbfresh
You can use an infrared thermometer to get an idea what the temps really are-I think you have a non-issue here.
Old Aug 18, 2010 | 04:58 PM
All_Motor_C5LS6
Thanks dougbfresh! I think you are right and I'm just paranoid, however, I'm going to try one last thing this evening, and thats burping the system throughly. I had a coolant flush last month and there might be some air in the coolant system.
Old Aug 18, 2010 | 05:00 PM
dougbfresh's Avatar
dougbfresh
There is no way to really BURP it-if it's been a month since the fluid change it's as good as it's going to get.
Old Aug 19, 2010 | 11:03 AM
All_Motor_C5LS6
You were right. I give up.
Maybe it's this front splitter that I put on that is making my car run warmer and that's not coming off.
Old Aug 19, 2010 | 11:17 AM
dougbfresh's Avatar
dougbfresh
HMMMM, didn't mention THAT That would be my guess.
Old Aug 20, 2010 | 09:32 AM
All_Motor_C5LS6
Problem Solved! Took the splitter off this morning just to see if that were the factor. Checked the coolant temps and they were 183*-185* in stop & go traffic and 180*-181* on the highway.
To Weird Cooling issues
