Torque Tube Coupling bolts?
I'm getting all of my parts together for a clutch/transmission change out and I'm planning on changing the torque tube rubber couplings. Can you reuse the bolts from the coupling or do I need to buy new? Other than GM where's the best place to buy the rubber couplings?
you can buy the couplings at the BMW dealership or ebay for pretty cheap, exact same couplings.... the bolts can be reused, aslong as there is no damage to them, mine snapped a few days ago when my coupling destroyed itself so ive got to replace it all.... good move replacing those couplings!
Paul, you could give ECS, MTI, etc a call. They would give you the answers that you need. They could probably ship out the parts to you too. You don't want to mess up this part of the job. Good luck.
St. Jude Donor '09-'10-'11
BOLTS
Bolts for mounting the flex couplings use the following bolts.
Part # 12456213 = Torx M10 x 47 mm 12 each
Part # 88894027 = Torx M12 x 52 mm 12 each
Banned Scam/Spammer
Received 1,319 Likes
I've heard that the BMW peices aren't the same.... and deteriorate. I'm not calling you a liar, it's just that there seems to be conflicting reports both for and against in different threads.
Some real junky couplers out there. I'd be tempted to do a solid coupler in the rear and shim the bolts so it runs true. Then, do the new Prothane poly coupler in the front. Best part is that you never worry about it again.
In fact, I expect I'll be pulling my car apart again soon and doing just that.
Peter
Peter
Your plan is OK as long as you understand that you are also the R&D department. I however would not suggest this to anyone as the parts have not been proven to be any better than the stock couplings that every C5 & C6 including the ZR1 use. GM guarantees them for 100K miles in the current Corvettes. Ask any of the aftermarket suppliers if they will give you that kind of warranty on their product.
If I have to replace mine I would go with nothing but the OEM coupler. There are good reasons why GM still uses them. Just my humble opinion.
I'm going to buy the stock OEM couplings, it's not worth the hassle to save a few bucks. But my mechanic said that I should buy new bolts.
It seems you know why the GM engineers picked the couplers so why don't you share?
If you have real proof that the Prothane coupler or a solid rear coupler are downgrades then post it up.
Despite the GM warranty, there are cars here that have had shredded couplers in a lot less than 100k miles.
On a similar subject, why would GM put in a skinny little prop shaft with a composite disk on it to keep it from becoming a skipping rope at high speeds when they could have put in a larger diameter shaft?
A manufacturer would never compromise....
Peter
Compromise, well, isn’t that why we have engineering? Engineering is taking as many factors as possible and developing a component with the best balance of all those factors.
This forum is filled with some very interesting people with backgrounds in a variety of disciplines. It’s a fun place to learn and read about new and in my opinion interesting things. This is the driving force that keeps me coming back. How about you?
Using the ZR1 100k mile warranty as proof is questionable. In my opinion, if a ZR1 gets flogged much while being driven the couplers will not last 100k miles. Also, none of them have enough real world miles to make any claims that the couplers do work for 100k miles in that car.
Peter
Really, so, are you familiar with the durability testing at GM? Care to explain what factors in this testing are flawed?
Really, are you monitoring all the miles on every ZR1 out there? Where are you getting this information?
I'll be the guinea pig. I'm getting 2 new Prothane six-shooters installed next week.
I agree with the others here on re-using the coupler bolts. Only if undamaged of course. If any are in doubt however, replace.
On a more Sserious note, if this really is your plan, how about getting photos and starting your own thread with the topic of these couplers. How much hp are you at, what diff gearing and other details on your car. I'm interested and I'm sure others would be as well. I hope they work out for you.
